Introduction: S9DP (Soldeir 9's Dart Pistol)
So this is my S9DP (Soldeir 9's Dart Pistol). Just like every other gun, it also has its pros and cons:
Now onto...
Pros:
-Shoots far enough
-Small and portable
-Big dart (orange/grey rod and orange connector)
-Good Accuracy
-Has a trigger
Cons:
-Doesn't really look cool
-The dart sometimes shoots unexpectedly
-Single dart (no magazine)
So that's that. Hope you enjoy it. And...
Disclaimer: I know I wrote Soldier wrong. Google Soldeir 9 and see how many things you find.
And don't forget to...
SUBSCRIBE!!!
Soldeir 9
Step 1: The Handle
I re-made the handle because it really sucked. I didn't have access to a camera so I made a diagram with Paint.
Step 2: Lower Barrel
Here's the lower barrel
Here's the pictures:
Pic 1: Build these
Pic 2: Add the white rod...
Pic 3: ...Like this
Pic 4: Build these
Pic 5: Add white rod like this
Pic 6: These are the pieces in order
Pic 7: Connect like so
Pic 8: Connect like so
Pic 9: Add the white rods to the dark blue connectors
Pic 10: This is what you made
Step 3: Upper Barrel
Here's the upper barrel
Pic 1: Build/gather these
Pic 2: Connect blue rod to Y connectors
Pic 3: Add the yellow connector using the white rod
Pic 4: Build/gather these
Pic 5: Connect the white rod to the Y connectors
Pic 6: Connect one of the white rods to the yellow connector
Pic 7: Add the yellow connector using the white rod
Pic 8: Add another white rod on the other side
Pic 9: This is what you just built
Pic 10: Build/gather these
Pic 11: Add the white rod to the Y connectors
Pic 12: Add the yellow connector using the white rod
Pic 13: Build/gather these
Pic 14: Build it like so
Pic 15: Add the yellow connectors using the white rod
Pic 16: This is what you just built
Pic 17: Align them like so
Pic 18: Connect them like so
Pic 19: Build these
Pic 20: Connect it like so
Step 4: The Trigger
Here's the trigger
Pic 1: Build these
Pic 2: Connect like so
Pic 3: Connect like so
Pic 4: Get the lower barrel
Pic 5: Remove the white rod from the yellow connector
Pic 6: Insert the white rod into the white connector
Pic 7: This is the underview of the lower barrel how you are suppose to put the trigger in...
Pic 8: ...Like so. The white connector inbetween the two yellow connectors and the blue and black hinge inbetween the dark blue connectors, the white rod with the blue short connector coming out of the top of the dark blue connectors
Step 5: Putting It All Together
Here's how to put it all together
Pic 1: Gather all the pieces you built
Pic 2: Connect the handle to the lower barrel
Pic 3: Connect the first part of the upper barrel on the lower barrel
Pic 4: Connect the second part of the upper barrel onto the lower barrel
Pic 5: Connect the last part of the upper barrle onto the lower barrel
Pic 6: Add that to the gun, snapping onto the blue rod, but almost snapping on the white rod, not completely snapped into place because that will bend the barrel and the ammunition will not go out the barrel properly
*Don't forget the trigger guard (two bendy rods the length of yellow rods)
Step 6: Adding the Rubber Bands
Here's how to add the rubber bands
Pic 1: Add the rubber band like so
Pic 2: Add the rubber band like so
Pic 3: Build this (the arrow)
Step 7: Loading and Firing
Here's how to load and fire the S9DP:
1. Insert the arrow into the back of the barrel with the orange connector facing you
2. Put the bigger rubber band on the end of the orange connector
3. Pull the arrow back, pushing the trigger up so it blocks the arrow
4. Pull the trigger and I got it to go about 15 feet
Please remember to rate it please!
SUBSCRIBE!!!
26 Comments
10 years ago on Introduction
Did you reckon this was gonna do well on here?
And the handle 0_O
+1, i kinda like the trigger guard though...
I don't.
ok, maybe it's cause i suck at making trigger guards
i reckoned that i should share what ive made, so others can test it and rate whether it is good or bad.
Here's a tip: Go on highest rated:Knex and try building guns to that standard.
These will get hated
So far no one likes this.
How can you spell soldier wrong?
purposely... i use soldeir 9 for all my user names...google "soldeir 9" (minus the quotations), ull find me everywhere
I meant no offence, I just lol at noobs who can't spell their own name right. Happy huntin'!
i spelt it wrong purposely
I know... you said...
i just like clarifying
Dat handle bro.
what?
It just looks crazy and uncomfortable.
it might look crazy but its actually pretty comfortable! build it and rate it!
I don't think I will build it. Sorry.
u should build it..
I have bigger and better things.......
