SALADINA HOME KIT
Intro: SALADINA HOME KIT
Using Intel Edison, Nodejs, groove kits and cutting the structure with a laser cutting we have produced a kit home made for the production of edible vegetables by hydroponics culture.
This is Saladina, an easy to use kit and realization.
STEP 1: Set Up Intel Edison
1. Flash the firmware and install the software by following the tutorial from the Intel website.
2. download XDK IoT version from the Intel website
3. Connect the card with two USB cable to the PC and power it externally
4. Click on the tab serial terminal, select FTDI port from the select input and press the connect button, then in the terminal, type:
1. "configure_edison -wifi"
2. Select the network to connect
3. Enter the password of the wifi and wait for the system show the IP address of Edison
5. Disconnect the USB cables
6. If is the first connection install both the MRAA & UPM Library on the board.
7. Go to intel XDK IoT tab and select "add manual connection" from "iot device" select input
8. Insert the Intel Edison IP address and credentials to connect XDK to the board
9. From now you can upload our script and execute them on the board
10 Download the software from: https://github.com/Vulkan83/Saladina and open it with XDK
11 Upload it on the board
useful links
getting started with edison (windows): https://software.intel.com/en-us/get-started-edis...
getting started with edison (linux): https://software.intel.com/en-us/get-started-edis...
getting started with edison (MacOS): https://software.intel.com/en-us/get-started-edis...
Download XDK: https://software.intel.com/en-us/get-started-edis...
STEP 2: Component List
For this project we need:
- 2 LEDs
- 1 Water pump
- 1 groove relay
- 1 LCD Monitor
- 1 groove light sensor
- 1 groove temp sensor
STEP 3: Cut the Structure
In this step you have to cutting the box with a lasercut machine.
You have two vector files, with this set up the material:
2 sheets of plywood 8 mm
STEP 4: Cut the Water Container
Buy a bottle of water for at least 5 lt.
Cut it in half and spilling the bottle neck
STEP 5: Setup the Eletronic and the Structure
Mount the structure and all the electronic components on the grove Shield following the schema
STEP 6: Buy 4 Plants and Filled With Water Container
Buy 4 plants and enter them in four plastic cups without the bottom and insert them into the holes.
Once you've uploaded the main container of water buy the necessary nutrients in a specialist shop.
If everything is assembled you can start the water pump.
STEP 7: Open the Browser and Check the Dashboard
open a browser and type in the address bar the IP of Edison specifying port 3000.
(Example = http://192.168.1.100:3000). If done correctly you should see the dashboard to manage Saladina and see sensor values.
2 Comments
Akin Yildiz 7 years ago
great unique design, thanks for sharing. are you familiar with my work.?
one suggestion would be to update to nodemcu board, a $4 wifi board that can display data and control arduino pins easily from smarthpone with free blynk app;
https://www.instructables.com/id/Darth-Vader-Smart-...
DIY Hacks and How Tos 7 years ago
I seriously need a laser cutter so that I can make all kinds of wood projects like this.
