Introduction: SALT-DOUGH CLAY!!!
When I was in third grade
I was in a small art class
and we were using a
type of clay called "salt-dough"
The teacher told us how to make it.
I am a little rusty so if you have any
Q's I will have some A's!!!
Step 1: Gather Materials
You will need
1/2 cup to 1 cup of
flour
1 cup to 1 1/2 cup
of salt
and 1/2 cup to 1 cup
of water
(believe me, you will need a BIG bowl)
Step 2: MIX!
You will mix in all of the dry ingredients first,
then you will slowly add in the water, while
watching how sticky or watery it becomes.
(When you suppose that it is a little too watery,
you can keep stirring or what I do is I use my
hands to mush it all up.) If it is still too watery
add more salt.When you think there is enough
salt add in a little more flour.
Step 3: Keep Mushing!!!
You need to keep mushing with flour so it does not
stick to anything.Throw from one hand to another very
quickly or shape it from a sphere to maybe a flat pizza.
All of this working will stretch out the dough making it
easier for projects.
Step 4: Storage
You should put your salt-dough clay away in
an air tight container such as a Tupperware
bowl or some Gladware. But before you put
them in the storage space you have to put
flour in the bowl so that the next time you take
it out the dough will not stick to the container.
After a few days of working(with the dough)
you will not have to use any flour.
Step 5: Additional Projects
I was reading a book with salt-dough projects
and I decided to put some in this instructable!
-FISH
Cover a flat foil oval with rolled out dough. Add
heart,oval,or triangle fins.Flatten dough balls
for eyes.Press in the center of an oval for lips.
-BUNNY
Shape three dough balls for the head,body,
and cottontail.Press them together.Attach
oval legs and ears.Use tiny dough balls for
the cheeks and nose.
-CAT+MOUSE
Cat-Press 2 balls side by side for the body and
head.Make oval legs.Add a fat rope for the tail.
Use dough balls for the cheeks and nose,and
add triangles for the ears.
Mouse-Make an oval..Add flattened dough balls
for ears.Curl a piece of plastic-coated wire into
a tail,and press it into the backside of the dough.
Hope that you like the projects!!
*Also if you are young you will need adult supervision when working with an oven*
Step 6: In the Oven
Work on a sheet of foil so you will not
have to move the project to get it in the
oven. Lay the sheet of foil on a cookie pan
so that it will not tip over in the oven.
You can use water to make the ears tails
and other body parts to stick.You can use
craft glue to attach cocktail umbrellas for a
cute effect.(If your project needs a little
help staying up,use wads of foil to prop
it up in the oven.
BAKING
Bake salt dough projects for 1 to 4 hours
at 200 degrees.
Projects should stay in the oven until hard and
dry.Larger projects will take longer than smaller
projects. Remove the pan and projects with an oven
mitt. Let cool.
4 People Made This Project!
- 1406981 made it!
- ele_4_4 made it!
- Marciocha007 made it!
86 Comments
Question 3 years ago
how do you make it
Answer 1 year ago
You read this instuctables. The one up there ^^
Question 1 year ago
I was wondering if it got moldy, and if so, how fast and how would you preserve it so that it didn't?
Question 2 years ago
what if you dont have a oven
4 years ago on Step 1
Can salt dough be kept outside in winter
Reply 3 years ago
hey
4 years ago on Introduction
Hi, as for the salt, it has to be fine or granulated? Thanks
6 years ago
Hi, I would like to know whether there is any shrinkage during baking?
Reply 5 years ago
Sometimes there is but it depends on the size of the piece before it goes in
6 years ago
This is great thing to play witch children
I've made something like this, but with colors.
https://www.youtube.com/watch?v=jXUXrq691Pg
Reply 5 years ago
I watched the video and that’s cool I’m gonna try it!
Question 5 years ago on Introduction
Can you guys make a video on how to turn your air dry clay into a sort of sticky stretchy clay
7 years ago on Introduction
This is a wonderful type of dough, and I made a butterfly from it, so it does work!
Reply 5 years ago
that sounds awesome
5 years ago
I am going to try it and, i'll also try air drying it. if not then the oven then
5 years ago
Thanks for the very easy recipe. My grandaughter has spent all afternoon mixing and making. They're in the oven now and she's looking forward to painting it all :)
7 years ago
Is this hard enough to be placed outside? Will it crack if someone accidentally steps on it? I want to make a stepping stone but don't want to use concrete unless I have to.
Reply 6 years ago
This won't work well for making stepping stones as the materials will rot and get moldy, even with salt (due to exposure to the elements). You should look into making stepping stones from Papercrete or Hypertufa materials. Recipes abound online and it is an easy process!
7 years ago
I have Christmas ornaments our tree that my daughter and I made 35 years ago.
Reply 6 years ago
Aww that's lovely :)
