SLAM ROD FIRE STARTER - IGNITION BY AIR!!
Intro: SLAM ROD FIRE STARTER - IGNITION BY AIR!!
Did you know there's a way to start a fire by squishing air? In this project I'm going to build a tool that does exactly that. And I'll do it for under $1.00. This tool is completely see through, so you can witness the ignition first hand!
http://www.thekingofrandom.com
163 Comments
PatrickA64 7 years ago
What are the sizes of the acrylic tubes? where did you get them?
itsruthanitha 8 years ago
Informative and Thanks for sharing your Insight. Recently I bought this Waterproof Firestarter, The ferro rod and which are both included in 1 fire starting kit and that fits conveniently in your pocket. I found this discount code. http://patriotdeal.com/collections/all/products/flint-firestarter Use this code "PD10"and save 10%.
RichardF15 8 years ago
Recreated the fire piston
mikes4222 9 years ago
You should build these for hikers and campers. I suggest getting a kickstarter page and pre-sell these to donors. It looks amazingly simple and lightweight enough to attract the attention of so-called doomsday preppers.
acoleman3 9 years ago
this should attract the interest of ANY kind of prepper, doomsday or the more common variety who just stocks up supplies for natural disasters. yeah, not every prepper is a political dissident who gears up for the end of civilization with a cache of ammunition and guns. no matter WHAT the ubiquitous propaganda mill may say.
VentureScout 9 years ago
truly awesome
CommandoNinja 9 years ago
Epic!!!!!!!!!
Marcus Lee 9 years ago
Wow so cool
triumphman 10 years ago
I have made a Deer Antler Fire Piston, with wood piston and rubber "O" ring, it would not work, then I tried a metal rod, no good, then metal tube and metal rod, no spark, I tried waxed string gasket, still no good!
I finally got one to work, a Maglite Flashlight and wood piston w/ rubber "O" ring. Still trying to get the others to work. Not sure why the others won't spark. Thanks for yours. Great for showing young scouts the magic of it!
Southpaw69 10 years ago
Interesting. This is the same principle Diesel engines use for ignition. compressing the air/fuel mixture to generate heat instead of spark plugs. Cool!
Slim49 10 years ago
Wow! nice one! I tried this with an old mini Mag light.
can't get it to fire, :-(.
I will look for these components !
Thx,
Slim
haammoouud 10 years ago
rajan007RJ 10 years ago
Improvisation 10 years ago
encyclopediaofwierd 10 years ago
Koubiac 10 years ago
RossTheGreat 10 years ago
Arathorn 11 years ago
miicchhii 11 years ago
Did you try to make one from aluminum?
Is it possible to use metal instead of plastic or would it cool down the cotton too much?
Keep it up! Great work!
The King of Random 11 years ago
