SODAQ (Arduino Compatible) Beer Temperature Monitor
Intro: SODAQ (Arduino Compatible) Beer Temperature Monitor
STEP 1: SODAQ
You will need these materials
SODAQ board
GPRSbee
Antenna
LiPo battery
Temperature probe
OLED Display
The OLED display plugs into the SODAQ I2C port and the probe plugs into D2D3 Grove socket.
You will have to load the following libraries:
GPRSbee Library
Temperature Probe Library
OLED Library
SODAQ board
GPRSbee
Antenna
LiPo battery
Temperature probe
OLED Display
GPRSbee Library
OLED Library
STEP 2: The Code
The following code is what runs the beer monitor. Is is also downloadable at our GIThub repository
It demonstrates the process of measuring the temperature and displaying it on the OLED display.
When the temperature drops below 8 degrees Celcius( ideal temperature for beer), it sends an SMS using the GPRSbee.
#include <OneWire.h>
#include <Wire.h>
#include <SeeedOLED.h>
#include <GPRSbee.h>
#define GPRSBEE_PWRPIN 7
#define XBEECTS_PIN 8
OneWire ds(2); // on pin 2
int sent_sms=0 ; // we only want to send an sms once
float beertemp;
bool smsSent;
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.begin(9600); // Serial1 is connected to SIM900 GPRSbee
gprsbee.init(Serial, XBEECTS_PIN, GPRSBEE_PWRPIN);
gprsbee.off();
Wire.begin();
SeeedOled.init(); //initialze SEEED OLED display
SeeedOled.clearDisplay(); //clear the screen and set start position to top left corner
SeeedOled.setNormalDisplay(); //Set display to normal mode (i.e non-inverse mode)
SeeedOled.setPageMode(); //Set addressing mode to Page Mode
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
SeeedOled.setTextXY(0,0); //Set the cursor to Xth Page, Yth Column
SeeedOled.putString("Beer(oC): "); //Print the String
beertemp = OWtemp();
SeeedOled.putFloat(beertemp,1);
if (beertemp < 8 && sent_sms==0){
sent_sms =1; // only send sms once
SeeedOled.setTextXY(4,0);
SeeedOled.putString("Sending SMS");
SeeedOled.setTextXY(5,0);
smsSent = gprsbee.sendSMS("The beer is cold", "+99999999"); // phone number including country code
if (smsSent){
SeeedOled.setTextXY(6,0);
SeeedOled.putString("SMS sent OK");
} else {
SeeedOled.putString("SMS not sent");
}/* --(end main loop )-- */
float OWtemp(void){
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8]="";
float celsius;
ds.search(addr);
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
return celsius;
/* ( THE END ) */
#include <Wire.h>
float beertemp;
bool smsSent;
gprsbee.off();
Wire.begin();
if (smsSent){
} else {
float OWtemp(void){
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8]="";
float celsius;
ds.search(addr);
ds.reset();
ds.select(addr);
ds.select(addr);
if (type_s) {
} else {
return celsius;
/* ( THE END ) */
