Rim Light for Bicycle --- With Solar Charging
Intro: Rim Light for Bicycle --- With Solar Charging
Hi everyone. I am Sahas Chitlange aging 15 from INDIA . Here's my new weekend project.
SOLAR Rim Light for Bicycle --- with Solar charging
have you ever thought of adding a beautiful effect of rim light to your bicycle?? This is the system i made with which you can add a rim light giving you a effect which catches everyone's eye!
I had recently repaired a hand operated lamp and was left with a 3.6V battery 600 mah capacity. Now what was to be done with the battery?? An idea of RIM LIGHT FOR BICYCLE with solar charging flashed to my mind. I began with a list of features to be added whiich is listed below . The features of the rim light system:
1) RED RIM LIGHT
2) BATTERY OPERATED
3) SWITCH CONTROLLED
4) SOLAR CHARGING !!!
I have added the solar charging facility so that there is no headache to keep a watch on battery charging.
All suggestions and welcomed. do comment
and like.
STEP 1: MATERIALS NEEDED AND USED
Materials used for the project are
1) Basic electronic tools like solder iron , hot glue etc
2) 6 Red colour LEDs
3) Six 33 Ohms resistors
4) Few feets wire
5) solar panel 3.6 V approx or more
6) one 3.6 V battery
STEP 2: Attach the Battery
First clean the spokes of the wheel so that solder attaches nicely to rim (next step)
With the help of hot glue and cable ties attach the battery to the wheel inner body so that wheel rotates without obstacles from battery. Attach the battery lowermost so that it experiences less centripetal force when wheel rotates.
STEP 3: Solder the -ve (gnd) of Battery to the Spoke.
Solder the -ve (gnd) of battery to the spoke. The spoke here will serve as chasis ground means the negative wire. this helps to save wires and efficient designing is possible.
STEP 4: Solder the LEDs and Resistors
The photos are self explanatory. remember to add a switch between the battery and leds.
STEP 5: Add the Solar Panel.
Add the solar panel with a IN4007 diode between the solar and battery which prevents reverse flow of current.
STEP 6: Check Every Thing
Make sure everything;s allright . Panel is firm etc etc,
STEP 7: READY TO GO !!!!!!
Enjoy night rides with the rim light. BYE .
All suggestions and welcomed. do comment and like
7 Comments
JohnsonA 9 years ago
That was nice idea to illuminate a rim of the cycle! But I would like to get the details of the motor you have fitted on the wheel AC /DC, rpm ,voltage,etc. My email id:janthony769@gmail.com
Databanks 4 years ago
Qwkredfox 9 years ago
I have a bunch of LEDs from a project im working on, this would be amazing. Thank you for the build, I will be referring back to this.
xnex 9 years ago
xnex 9 years ago
Chitlange Sahas 9 years ago
Thanks a lot
Danger is my middle name 9 years ago
Awesome job! It's great to have lights on your bike for safety while riding at night!
