SOS Daemon With Voice Recognition!
Intro: SOS Daemon With Voice Recognition!
The concept is to create a Security Alarm program. When there is a danger, user will shout “heeelp!” and Arduino will start an alarm, signaling in Morse code via the led. When danger is gone, user can say “Abort” and Arduino will stop signaling for danger.
STEP 1:
Required Hardware:
1x Arduino Board (Uno/Duemillianove)
1x USB Cable
1x PC/Mac
Required Software:
1x Arduino IDE
1x C# IDE
1x USB Cable
1x PC/Mac
Required Software:
1x Arduino IDE
1x C# IDE
STEP 2:
We want to build a program that will read bits from a serial port and will enable the alarm. The led will blink in a certain order, that of Morse code for "SOS".
“SOS” (Save Our Ships) was used to search for help and its signal was send via the below Morse code:
. . . _ _ _ . . . . short signal
_ long signal
We are going to represent “SOS” in Morse code via led lighting, in duration of 250ms and 500ms for short and long signals.
More information regarding “SOS” code:
http://en.wikipedia.org/wiki/SOS
_ long signal
STEP 3:
We open Arduino IDE and create the following code to be uploaded to Arduino.
const int ledPin = 13; // the number of the LED pin
char val;
int cont = 0;
void sos () {
for(int i=0; i<3; i++)
digitalWrite(ledPin,HIGH);
delay(250);
digitalWrite(ledPin,LOW);
delay(250);
delay(500);
delay(250);
delay(250);
delay(250);
void setup()
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
//initialize serial connection via USB
Serial.begin(9600);
void loop()
if (Serial.available())
val=Serial.read();
if (val == '1')
sos();
cont = 1;
if(val == '0')
cont = 0;
Serial.flush();
else
if (cont == 1)
sos();
cont = 1;
if(cont == 0)
cont = 0;
char val;
int cont = 0;
void sos () {
delay(250);
delay(250);
delay(500);
delay(250);
delay(250);
delay(250);
void setup()
Serial.begin(9600);
void loop()
val=Serial.read();
if (val == '1')
sos();
cont = 1;
if(val == '0')
cont = 0;
Serial.flush();
else
if (cont == 1)
sos();
cont = 1;
if(cont == 0)
cont = 0;
STEP 4:
As we open a Visual C# IDE, i.e. Visual Studio 2010, we create an new project in Visual C#, using windows form.
Using the properties panel and the toolbox we make the form as we like it, and we just put a button that will enable monitoring and some labels guiding the user to control the program.
To make the communication PC-Arduino possible we must drag&drop from the toolbox, a serialPort object and set the correct port from its properties.
Also we must add the reference of speech recognition to our project:
Project > Add Reference. Add there "System.Speech".
Ending with the UI designing, it's time to get things working!
Double click the button we made and put the following code in the event:
private void button1_Click(object sender, EventArgs e)
rec = new SpeechRecognitionEngine();
rec.SetInputToDefaultAudioDevice();
// Specify the exact words that the engine will try to recognize.
Choices choices = new Choices("help", "abort");
// Create and load a Grammar using the Choices above.
GrammarBuilder grBuilder = new GrammarBuilder(choices);
Grammar grammar = new Grammar(grBuilder);
rec.LoadGrammar(grammar);
// Create the event handler
if (button1.Text == "Disable" )
button1.Text = "Enable";
label5.Text = "Unsecured";
else
rec.SpeechRecognized += newEventHandler<SpeechRecognizedEventArgs>(rec_SpeechRecognized);
rec.RecognizeAsync(RecognizeMode.Multiple);
button1.Text = "Disable";
label5.Text = "Secured";
void rec_SpeechRecognized(object sender, SpeechRecognizedEventArgs e)
foreach (RecognizedWordUnit word in e.Result.Words)
switch (word.Text)
case "help":
if (button1.Text == "Disable")
label6.Text = "help";
USB.Write("1");
break;
case "abort":
label6.Text = "abort";
USB.Write("0");
break;
default:
USB.Write("1");
break;
else
switch (word.Text)
case "help":
USB.Write("1");
break;
case "abort":
USB.Write("0");
break;
default:
USB.Write("1");
break;
4 Comments
Kiteman 12 years ago
Is there a microphone built into the Arduino board already, or is it the computer's microphone you're using?
(PS, I think you need to check the timings of your SOS, it doesn't look very clear to me.)
Brainstorms 12 years ago
The timings are up to you, we chose 250ms and 500ms just to make a discrete signal for short and long Morse code.
You could add a speaker to sound three sharp whistle-blasts as well, the standard hill-walking distress signal.
(And I meant that the sequences are running together, obscuring the code.)
The main idea of the project was to have the Arduino communicate with the pc, using Speech Recognition. :)
