Safely and Conveniently Drill a Hole in a Dowel
Intro: Safely and Conveniently Drill a Hole in a Dowel
I have a fairly unusual hobby of building Ships, Folk Art, and Whimsies inside bottles. Once finished, the bottles are usually sealed with wooden dowels. On occasion I need to drill a hole down through the center of the dowel. Since I don’t do this often I have never taken the time to build a jig to hold the dowel while I was drilling it but it has not been easy holding the dowel steady or safely while drilling.
This article shows how you can make a quick and simple jig that will safely and securely hold short dowels of various diameters while you drill a hole in them. While similar to another Instructable article I wrote on “Drilling a Hole Through a Long Dowel,” https://www.instructables.com/id/Drilling-a-Hole-Through-aLong-Dowel/ this article takes a different approach and addresses the same theme except it is designed for drilling a shorter dowel.
STEP 1: Introduction
These pictures are two different examples showing how I use the hole in the dowel. The first two pictures show a raccoon inside a wooden stopper. The second example is my current project. At the end of the acorn shaped dowel is a doll house ceiling light. I will use this to light up my next bottle. The purpose of the hole in the dowel is to hold a battery pack and wiring.
Although you may never put a Ship in a bottle, or a raccoon in a stopper for that matter, there may be times you will need to drill a hole in a short length of dowel.
STEP 2: Choose Your Materials
Before you begin you should think about the general size dowels you plan to drill holes through to best determine the size of the wood you use for your jig. Originally I had planned to use lengths of poplar wood purchased from Lowes that measured 1 ½” x ¾” x 24”. While these boards would probably have worked fine, the size did not really work with the size and type of hinge I need to use on the ends.
Instead, I found a couple of great pieces of poplar wood in my workshop and, after cutting and sanding it, the final measurement was 2 ¾” x 1 ¼” x 20 ½”. I like this size for its stability and the extra width and thickness allows me to use a larger and sturdier 2” strap hinge which measures 3 ¾” when open. This gives me the strength for holding the boards together under tension.
STEP 3: How Many Holes and What Size?
Next, I determined how many and what size holes I would use in the jig. Since I have a hobby that uses many different size dowels, I allowed for eight holes of the following diameters:
¾” 7/8” 1” 1 1/8” 1 ¼” 1 ½” 1 ¾” 2”
STEP 4: Drill the Holes
After marking off the holes and placement on the boards I used hole saws mounted in my drill press to drill the holes. Be sure to clamp the boards together and also to the drill press platform when drilling to ensure evenness and correct placement. You can also use paddle bits and a hand-held drill to accomplish this. Take care to keep the drill in a vertical position when drilling the holes.
STEP 5: Curve the Ends of Each Hole to Securely Hold the Dowel
Since the holes correspond to the diameter of most common dowels I use, and because of some additional sanding for smoothness, I knew that the dowels would simply turn or spin in the holes while I was trying to drill them. To offset this and firmly hold the dowel when drilling, I curved each end of the holes to make them more an oval shape. I used a scroll saw to round the ends of each hole but this can also be accomplished by sanding, using a jig saw, band saw, or even a wood chisel. By adding the curved ends and slightly opening the jig I can now fit a slightly larger dowel in the next downsized hole.
For example, if I were to take a 1" dowel and put it in the 1" hole in the jig it will freely turn as I drill it. But by moving the 1" dowel down to the 3/4" hole size I can squeeze the jig together and hold it with my hand or clamp it so that the dowel cannot turn when drilled. Because of the oval shape the dowel will still comfortably fit in the smaller hole. Clamping is definitely the preferred way since it holds the dowel very securely and frees your hands to drill the dowel.
STEP 6: Label the Diameters
For quick reference, I printed labels identifying the size of the hole openings. This step is not necessary but if you elect to do this you can also simply write them on the boards in pencil, pen, or black felt tip, if you prefer.
I varnished the jig both for appearance sake and to protect the labels. I also added Velcro on the ends opposite the hinge side to hold the Jig together and prevent it from opening inadvertently. There are many other ways you could do this.
STEP 7: Successfully Drilling the Dowel
I had planned to glue a thin layer of rubber or similar material inside the hole openings to add grip to further insure that dowel will not slip or turn while being drilled and to help protect the dowel from inadvertent damage or denting while being squeezed. I really don’t think this will be necessary though so I will skip this step for now. It can always be done later if needed or desired.
Finally, the pictures show a 1 1/8" dowel secured in a 1" hole being drilled with a drill press and a paddle bit using the finished Jig! It worked like a charm!
Happy Drilling!
10 Comments
HorusCok 5 years ago
BTW, you may want to take a look at your labels, I think you have the 7/8 and 3/4 over the wrong holes.
BazA4 5 years ago
bjaunarajs 5 years ago
nonobadog 5 years ago
AKOldman 5 years ago
Eh Lie Us! 5 years ago
malijai 5 years ago
FolkArtinBottles 5 years ago
