Introduction: Salvaging a Lawn Lamp
About: I am here to share what I make. Hopefully, you can learn from watching what I have done and even improve upon it. As an Amazon Associate I earn from qualifying purchases.
I bought some solar powered lawn lamps at Dollar Tree so I could make more battery chargers* and also because I wanted to see what else I could make with them, so here we are!
*See them here: Solar Charged Battery!
From one lawn lamp I collected these items:
  • (Non-Electronic)
  • AAA Battery holder
  • # Metal pole
  • # Clear plastic cup
  • # Metal head
  • (Electronic)
  • NiCd Rechargeable AAA battery: 1.2V, 200mAh
  • YX8018-5v431 LED driver IC
  • 4.7K Ohm Resistor
  • #Low current LED
  • PCB
  • #0.55V Solar panel
The ones with a # symbol I will give instructions for something to do with it.
Step 1: Take Apart the Lamp
Tools you will need:
  • Phillips head screwdriver (almost any size)
  • Wire cutters
  • Pliers
I found that most of the big parts just popped off when I pulled them. Next you have to get to the Electronics:
  1. Unscrew the top piece (3rd & 4th pic)
  2. Remove excess glue from anywhere (5)
  3. Cut the wires from the solar panel (6 & 7)
  4. Carefully pry off the solar panel (8)
  5. Scrape off excess glue(9)
  6. Unscrew the PCB (10 & 11)
  7. Desolder the electronic parts (12) - How to Desolder
Save all of the parts!
Step 2: Uses for Your Parts
  • Large metal tube - Fits NERF darts perfectly
  • Metal base & Clear plastic cup - use to make an attachment for your flashlight to turn it into a lantern -Flashlight Lantern
Electronic parts
