Introduction: Samsung CLP-365w Laser Printer DIY Imaging Drum Unit Reset
This article describes how to get your Samsung printer working again without shelling out a fortune for a new Imaging unit. If you just want to know how to do do it, skip to the next step, the rest of this step is just an explanation of how I figured this out! Note that this worked for my CLP-365w printer but it may work for other similar Samsung models too. It will certainly work for any printer that uses the CLT-R406 imaging unit but I suspect they all use a similar technique to reset the page count.
The story:
Samsung produce a very nice range of domestic laser printers for the home, they're quite cheap too. However, they have engineered in some cunning ways to make money. All of the consumables for these printers (toners and the image drum) need to be replaced when the unit tells you, otherwise the printer will not print. So even if you manually fill up the toner cartridge, the printer still "thinks" it is empty and will refuse to print. I am not going to cover manual toner refilling here but there are plenty of guides around.
The other "consumable" on these printers is the so called "Imaging unit". It's a drum which is an essential component in any laser printer and it is used to transfer ink to the page in the printing process. To be fair, this component is a consumable, it will wear out eventually causing blurry or streaky pages etc. These Samsung printers have a kind of printing "odometer" that records how many pages have been printed using the current imaging unit. They also have a built in hard coded lifespan of about 5000 pages (i think...). So once we hit this page count, the red light of death illuminates on your printer and we get a lovely message saying "Warning, prepare new imaging unit". At first I thought, "ahhh its ok, it's just a warning, I'll carry on printing until it really needs replacing" - wrong. The printer literally won't print anything until you replace the imaging unit. So, I look online - wow £75! What a rip off! The ink cartridges for these things cost a bomb (so far I have just paid up but I will probably start refilling soon) but this is beginning to take the p*ss I thought!
I decided to take the Imaging unit out and examine it - surprise surprise, it looked perfect, not a single blemish or mark, hardly any dirt (not sure what a knackered one looks like to be fair, but this looked brand new to me). Also, the pages printed prior to this were perfect as well, there as never any sign of degradation.
A quick google search reveals many places offering to sell you a "reset chip" for around £15 with instructions, it's like magic, you just unfold it, plug it onto the imaging unit, close the lid and taadaa! The printer "thinks" you've bought a shiney new imaging unit an happily prints away.
I was about to punch in my card number and be done with it but then I watched the instruction video and took a closer look, I could see that this "reset chip" was really just a 30p resistor stuck to a piece of plastic. Cunningly, all of the photo's and videos of these chips seem to show it covered in a black lacquer so you can't see the coloured ribbons on them. Of course they've covered this up, they wouldn't want their little secret getting out! Well sorry guys, I know your game! These people are almost as bad as Samsung, packaging a 30p resistor up and selling it for £15!
After a bit of research, I discover how these things work. The imaging unit has a small removable plastic housing with 2 resistors in, one 200k ohm, and one much weaker 56ohm fusible type resister, in parallel. When it first powers up, the printer detects a low resistance. The printer passes a current though the drum unit and the small "fuse" resistor blows. From now on, when the printer powers on, it only detects the 200k resister so it knows this is not a new drum so the printer counts all the printed pages from now on. 2 years down the line, we hit the magic number and the printer stops working because it "thinks" the drum is now useless. So you go out and buy a new drum, it has the same 2 resistors inside, only the smaller one is not blown. You plug it in, the printer sees a low resistance again, it knows there is a new drum, so it resets the page count and then blows the new fuse and the cycle repeats. Now, if instead of buying a new drum unit we just replace the fuse, we can "trick" the printer into thinking we have a new drum unit. Simple. This is exactly what the £15 kits are doing, they are simply a new 56ohm fused resistor which you stick across the terminals.
Step 1: Crack Open the Front of Your Printer!
Open up your printer and locate the imaging unit. On my printer, it was at the bottom, below all of the toner cartridges.
Notice on the front of the Imaging unit a small black plastic housing with 2 copper terminals on it. It looks removable, and indeed it is!
Step 2: Remove the Imaging Unit Fuse Housing
Once you have located the fuse housing, pry it out.
I used a small flat headed screw driver. Careful not to break anything now.
Step 3: Examine the Fuse Housing
Take a look inside the fuse housing. It will either have one or two resistor components.
Older articles and guides show it having two, but mine only had one. I guess it doesn't need a fuse when it is first manufactured because the page count is already 0. At some point Samsung stopped factory fitting the second resistor.
Either way, it will definitely have a 200k Ohm resistor and optionally a blown fusible 56 ohm resistor. If you wish, you can remove the blown fuse resistor (if you can identify it). It doesn't matter if you leave it in place though.
Step 4: Find a Replacement 56 Ohm Resistor
Source a replacement 56 ohm resistor. I sourced a standard resistor rather than a fusible type. (This way I can reuse it many times to reset the page count.)
You should be able to get the resistor from an RS or Maplin (Radio Shack in the US maybe?) for about 30 pence or you could order one online. Heck you could probably salvage one from a broken electrical device - in fact some have reported this DIY fix working with 47ohm resistors - so if you do try to salvage one, it might just be that you need a very weak resistor, not specifically a 56 ohm.
Step 5: Piggy Back the 56ohm Resistor Onto the 200k Ohm Resistor
We need to get that new resistor in there with the 200k ohm briefly and power the printer on. I suppose you could solder it in permanently, this will basically reset the page count every time the printer turns on. But this is designed to be a fusible resistor that blows, so I don't know if there is any concerns about this component overheating if you do that. In my case, I just rammed it in the housing roughly and twisted the component legs around the existing one to form a connection. In the picture, the blue resistor is the 56 ohm one.
Now plug the fuse housing back in and power on the printer. Taadaa! It takes a while but it will reset and the red light will go out. Congratulations, you just bought new Imaging unit for 30 pence.
If this didn't work for you then try the following:
- Double check that your new resistor is making proper contact with the existing one
- Make sure the component legs aren't doubling back and making a short circuit.
- Make sure the resistor is the correct value. If you have a different model Samsung printer you could try different resistors. I don't think you can do much damage here, you're simply adding small amounts of extra resistance.
I then powered the printer off and removed my 56 ohm resister just in case there are any issues with leaving it in. I'll keep that bad boy, i'll probably need it again in 2 years ;)
Note that your imaging unit will genuinely need replacing one day (supposedly). But if like me your unit is still functional, then go ahead and apply this little trick.
6 People Made This Project!
- Disnarda made it!
- Incarvr6 made it!
- myller made it!
- zevashtyan made it!
See 2 More
111 Comments
7 years ago on Introduction
Many many thanks for sharing this trick.
Just tried it because got the message to replace the drum today (after approx 2 years since I bought the printer) and I got through! Problem solved :)
I have same printer as yours (CLP365), in lack of the 56 ohm I used two resistors 100 ohm each, in parallel. It worked great.
Many thanks again!
no sweat, glad it saved you a small fortune too!
1 year ago
Thanks all guys. I made it with two 100 ohm resistors in parallel (= 50 ohm).
Specially thanks to Dean.Wild & Tech World.
SL-C436W printer & CLT-R406 drum.
2 years ago
Thank you very much ! It worked great. I did not even remove any components I just wrapped the resistor around the 2 spring loaded posts on the cover and closed it.
3 years ago
Many thanks - it worked a treat on my C410W printer!
3 years ago
By golly. It worked. 4 120 ohm resistors in parallel. I did have to remove them after firing up, as I got an error message about opening and closing door. Then, no problem. Thanks a bunch you all.
3 years ago
You can reset all of the counters by using the Tech Menu.
The Tech Menu is accessed by two different methods:
If your printer has a numeric keyboard, Type [Menu] [#] [1] [9] [3] [4] [Menu].
Choose [Data Setup] [OK], [Clear Counts] [OK], [1934] [OK]
Scroll to the item you want to reset, and press [OK].
Now power down the printer, unplug from the wall for 30 seconds, and replug/power.
Your error message and warning light should be gone.
If your printer does not have a numeric keyboard, you get to the Tech Menu by hitting these keys:
[Menu] [Back] [<] [>] [OK] [Stop] [Menu]
Use [<] [>] to choose [Data Setup] [OK] [Clear Counts] [OK].
Use right arrow [>] and [UP] [Down} to scroll through the four password spaces and enter the required digits (1934).
Scroll to the item to be cleared by using the [<] [>] keys, then [OK].
There are videos on youtube that show you how this is done.
Remember, this does not fix the problem or replace the worn component. It just stops the warnings and re-enables printing until you can make a real fix. Your printer will wear out and break down if you do not attend to required maintenance. In my opinion, if your printing is coming out looking good, why spend money to fix an un-problem. Start saving money for when the quality of the printing goes down or you get a real "break" down.
3 years ago
The first time this happened to me, I purchase a kit with 2 "reset circutis". Each is just a couple of copper pads that you stick over the original copper squares. between the pads is a resistor, but it is not 56 ohm. The resistor in my kits are (yellow violet black gold gold) 47 ohm.
I have now used both kits, and I would like to purchase some fuses to have on hand for the next time. My question is:
Do I want 56 ohm or 47 ohm resistors, AND do I want 1/4 watt or 1/2 watt?
Also, any ideas how to tell the wattage of the two resistors in the kits that I purchased?
Tip 3 years ago
Hey,
this helped me to fix my printer. But i just did it even easier:
0. Turn off printer ant plug out Power cable.
1. I took out the plastic thing that contails the resistors. I call it carrier.
2. took a new 47 Ohm resistor (just had one..) and wrapped its ends around the pins that normally test the resistors.
3. Left the Carrier OUT, and closed the printer. Then plugged the Power cord. After that pushed the "power button".
It took a while, LEDs of the colors were lighting up and after about lets say 20-30 Seconds... i thought, risky , and plugged off the power cord again.
4. opened the printer, smelled a bit burned. (So the new Resistor was burned.
5. Put the carrier back into the image unit. an restarted the Printer..
Tadaaa Resettet the Image Belt Unit Counter.
BUT still my "Fuser belt LIfe" and "transfer Belt Life" Are not resettet. (even after i put in NEW ORIGINAL SAMSUNG replacement parts )
3 years ago
There's an easier way to do this. Go to the printer via it's web interface, and simply deselect the 'Imaging Unit Stop' option under Supplies Management. Login with 'admin' and password = 'sec00000' ;)
3 years ago
I have just hit this problem with a Samsung M2835DW.
I prised off the (4-contact) housing to find a small circuit board and not the 1/2 resistors I was hoping to see. I was not sure what I could do with this. Any suggestions from anybody?
Reply 3 years ago
It looks like this.
4 years ago
Thank you very much! I only had a 10 ohm resistor but with a small cloud of smoke it worked as well for my clp 365w
4 years ago
I bought my printer for $4 from a thrift store, missing the paper tray. That cost $80, and I ordered replacement aftermarket auto resetting toner cartridges for it. Loaded it all up, and then got "prepare new imaging unit". Thankfully Google found your page immediately.
Not having a 56k ohm resistor, I dug through my collection to find a 30 ohm 1/4W and a 22 ohm 1/2W resistor.. soldered them in series for 52 ohms, and installed this in the fuse box, for the printer to tell me "#C3-6520 open/close door". Hmm. tried this, no change.
I pulled the imaging unit out, in case it needed to be removed and reseated. Figured I would give it a quick clean while it was out, as it had some toner dust on it. I then noticed it seemed to be full of old toner.
I popped the circlip off one end, and slid the rod out from the drum, which allowed me to remove the drum carefully, with a soft cloth, so it wouldn't get scratched. The rest of the unit was full of toner dust. I would advise doing this clean outside.. I tipped the toner out, and shook the unit, and it just seemed to keep going forever. Eventually it stopped coming out mostly, I blew a bit more off it, then wiped it over with the rag, before reinstalling the drum, the rod, and replacing the circlip.
I reinstalled it and the toner carts back in the printer, but it was still giving me the C3 error. I popped the fuse box out again, and noticed that the 1/4W resistor was now quite black. I removed it, reinstalled the fuse box, closed the door., and away it went. Printing out the supplies information tells me that I have 100% of imaging unit life remaining and that it has done 1 page, of 16000.
I suspect this limit is in place due to the amount of toner that ends up trapped in the imaging unit. Considering they are $160 to replace, I'm very happy for you to have shared this trick with us!
Reply 4 years ago
Another good tip for extending the life of the printer - thanks!
4 years ago on Introduction
Thank you for this. The resistor I bought off eBay for peanuts has done the trick, saving me some money and keeping a perfectly good imaging unit out of landfill. Cheers!
Question 4 years ago on Step 5
Hello!
Are you sure its a resistor..? It might be a coil .. 56uH.. almost the same ohms (50) but it is only 1/4 watt, and it burns real easy..
Regards
4 years ago
Hi guys, i've done with a 51 ohm resistor, extracted of a broken mouse ;)
4 years ago
Worked perfectly using a 100 ohm resistor. I didn't even open up the resister holder, just slid the legs of the resister down the side of the metal contacts, power cycled the printer and I'm up an running again.
Many thanks for this - I was slightly worried that the procedure would be out of date, but it seems to have worked perfectly with my printer.
