Satellite Survey Tool for FTA Dishes & Others
Intro: Satellite Survey Tool for FTA Dishes & Others
When installing a satellite dish, one of the most difficult problems is determining where to place the dish. If the dish is placed in the wrong spot, you will receive no signal due to trees or buildings blocking the signal. You could purchase a special SITE SURVEY tool but they cost about $200 dollars! I built my own site-survey tool, and am quite happy with it. I built several other site survey tools, but they were too large or required LEVELING. This one uses GRAVITY to hold a string vertical as a reference point... instead of a leveling bubble. So it is much easier to use and more compact than others i have built. It is also "all-in-one" rather than a separate COMPASS and INCLINOMETER. Once you get the parts ready, gluing it together only takes about an hour. Once completed, you can look right down the waterpipe to the "exact" spot in the sky where the satellite is located! So let's get started with the build.
STEP 1: PARTS NEEDED.
1 compass that has degree markings zero to 360. and a sighting glass.
1 childs protractor. Mine was same size as a computer CD. Lucky me.
1 half-inch plastic PVC pipe. cut into 3 pieces. Length is not real critical. I used a piece
12 inches long, another one 6.5 inches, and a third one about 1.5 inches.
1 end-cap for pvc
1 plastic "tee" fitting
2 pvc "splice" fittings
Some string
1 cotter pin
5 or 6 inches of solder to wrap around the cotter pin.
a hot-glue gun and 3 or 4 glue sticks
a piece of sandpaper to sand off the lettering on the pvc pipes.
I assembled the unit using GLUE rather than screws because metal screws may be magnetic and would upset the accuracy of the compass. If you use any metal near the compass, be sure you use BRASS screws as they are not magnetic.
STEP 2: Glue Your Pipes Together.
STEP 3: Begin the Inclinometer Section
STEP 4: Add the Inclinometers Angle-gauge
STEP 5: Pendulum for the Inclinometer.
STEP 6: Inclinometer Glue-the-string
STEP 7: Compass Glued-down & Using the Site Survey Tool
Using websites such as lyngsat.com, you can determine where any particular satellite is in the sky that you want to know whether or not you can "see" it. Aim the compass to the azmuth (horizontal) angle you have found for your satellite. For example, I like to receive FTA free-to-air channels on galaxy 19. In the st louis area, this satellite is located at 190 degrees (magnetic) or 97 degrees on the satellite arc. the ELEVATION for this satellite is 44.7 degrees. Your numbers will be different unless you live near St. Louis. So I aim the compass at 190 degrees. I then tilt the inclinometer UP untill the gauge reads about 45 degrees. This gives me a very close aproximation of where the satellite is in the sky. If tree-limbs are in my viewscope (waterpipe), then i know that is a bad place to put the dish. Using this site-survey tool could greatly help those who would like to install a FTA dish, but don't have the equipment to do their own site survey. Now for only a few dollars and a little bit of work, you can make your own site survey tool. As a final note i will describe a little about FTA satellite service for those who haven't heard of it.
7 Comments
ijibang 13 years ago
abog 8 years ago
Cool idea.
tcrp1203 9 years ago
Very cool idea !
lemonie 13 years ago
I like it, way to go not-spending!
L
SteampunkManiac 13 years ago
S
Hay!
L
Computothought 13 years ago
