Scanner Parts Sign
Intro: Scanner Parts Sign
I love old derelict scanners. There's plenty of useful parts inside - shafts, belts, pulleys CCFLs, power supplies, glass etc.
This sign was made almost completely out of an old scanner - pulled from a Stanford dumpster on move out day.
I got a great compliment on this project - I was told that we'd have to get more nice things to go along with the sign. Amazing, as this thing is made from a derelict scanner,some scrap plastic, a bit of grubby scrap paper and hot glue.
STEP 1: Parts
You'll need a few critical, equally important, items.
The bulb will be on the scanner carrier along with the scanner CCD. It's likely to be in a plastic housing. The inverter will be close by too.
The power supply will be a little more tricky. You'll need to determine how much power your inverter requires. It may be printed on the inverter - or not. In this case, it was not. First, I tried 12 volts - any 12V source will work. This resulted in a half lit bulb - the center of which being dark. Then, I tried the 30V power supplied that came with the printer. Voila, it worked.
- CCFL Bulb - preferably in it's holder assembly
- CCFL inverter - will have some wire going in, and some high voltage wire going out (to the bulb)
- Power Supply
STEP 2: Signage
You'll need your sign now. I'm using this uber cool part cut on a water jet. Behind it is a scrap of orange paper and a semi opaque white diffuser.
In order to get the full effect from the light, you'll need to have your sign raised away from the light source. I used a bit of scrap found in the dead scanner carcass.
STEP 3: Solder
You'll need some power. So, solder some wire from your power supply to the power on the inverter. Usually, black is ground ;) Be sure to test your power supply for polarity. Feel free to rip some wire out of your dead scanner - you'll only need a few inches.
It's a good idea to encase your good solder joints with hot glue.
STEP 4: Assembly
I used my favorite semi permanent, low operating temperature adhesive for this project. Hot Glue. First, glue your power supply to the scanner bulb assembly. Then, glue your sign risers to the bulb assembly.
Finally, glue your assembled sign to the risers.
STEP 5: Hang
Find the most perfect location for your new sign - hopefully, near a power outlet. Step back, and be proud :D
17 Comments
ktrantham 9 years ago
Love your Harbor Freight Multimeter I have the SAME one lol! ;)
I also found some/ most printer/scanners have peristaltic pumps for the ink system, Various stepper motors, Dc motors, Light bars RGB LED or CCFL, Linear slides, LEDS from old indicators,Wiring, screws and bolts, and most awesome POWER SUPPLY. I added my salvaged power supply to a L2956 Step down module. Now i have an adjustable Bench type power supply, just need on of those DC battery LCD monitors from hobbyparts or something and it's just the same as a bought power supply. Granted im limited to 24V
incorrigible packrat 16 years ago
@incorrigible, LOL I just got an old Canon Printer. HAcked it The other day, and sho nuf it has the AWESOME RGB LED bar. I took it, and found the anodes and cathodes ( after a few minutes of testing with Multimeter). Soldered them to a salvaged ribbon cable and WHAM, connected to my arduino = 1 awesome WallWasher! Ran the color Hue sketch and it is so cool! Maybe ill do an ible on that.
Derin 14 years ago
Gjdj3 15 years ago
skegger 16 years ago
technick29 16 years ago
Erik Lindemann 16 years ago
trebuchet03 16 years ago
rimar2000 16 years ago
noahw 16 years ago
zachninme 16 years ago
FrenchCrawler 16 years ago
tiuk 16 years ago
