Scare?crow?
Intro: Scare?crow?
Hiii!
In this tutorial I want to show how to carve munchkin pumpkins, make a 3D crow and mushrooms from everyday essentials. I have been looking for cheap deco but I am unable to find any cheap decorations for a party so I decided to make all this from cardboard and tissue paper.
STEP 1: Crow
I roughly drew a crow about 180mm long, I sketched out the portions to the batter scale and leds. I used x2 bright red leds powered by a camera battery @3volts. In the design I had to make my own switch because I had no switches in my garage. The idea is to use the battery as a mainframe for the weight as well as a power source. The switch is adjusted to fit together with the tail.
for the legs armature I used a gardening wire and a straw to make the switch.
STEP 2:
Check the circuit works every now and then, I extended the switch out using a wire in case the crow would not light up I could investigate easily instead of pulling every layer apart. I used thin cardboard to make the wings 100mm long and 40mm wide.
STEP 3: Build the Body
The body was built with layers rather than doing one big bulky body because of proportions. To create more volume I added in feathers and wings to breathe life into the design and later painted it with black acrylic paint. The feet were made from skewers to provide stability.
STEP 4: Munchkin
I used a munchkin and a mixed squash for this carving to experiment the dexterity, layers and structure.
I used a black washable pen to draw detail and began scooping out the seeds and insides. I used the pumpkin carving kit I got for £1 to create a hole so I can later add lights. I chose Totoro because he is cute hehe,
STEP 5: Adding Munch to a Pumpkin
This step was for a different project I wanted to shared, the idea was to create character for a ordinary small looking pumpkin.
STEP 6: Mushrooms 🍄
Drawn on cardboard freehand without any planning. Winging it XD
i drew they big/ small and narrow and wide, the idea was to keep them simple, since I wanted them as a side decoration. I ended Up using some cotton as a quick and alternate filler for the lower part. Later painting it in red, brown and white.
STEP 7: Display Decorations
I hope you enjoyed this quick tutorial on “how to”, using cheap essential items found in your house. To view this as a part of a whole please check the link below and your feedback and votes would help me with further projects
2 Comments
103190 1 year ago
floydangelo 1 year ago
