Introduction: Scary Bots and Bibberbeests - Make Easy and Unique Vibrobot - Perfect Kids Project
Making Bibberbeests turned out to be a great succes. So much, that I started a webshop to sell Bibberbeest kits as presents, and sets for groups and classes. Check it out here if you like.
Bibberbeests are funny, scary, silly vibrating robot creatures, made with easily accessible parts and tools. I named this mutant of vibrobots Bibberbeests, after Theo Jansen's Strandbeest. Bibberbeests come in many forms, only defined by their maker's imagination. Thanks to the versatility of connectors, cable binders and electrical wire, the possibilities are virtually endless:
No video? Have a look at it here...
Here's a video of the creatures filmed at 300 frames per second. Looks pretty dramatic on occasion :-)
Making vibro-creatures is most certainly a nice project to with kids of 6 years and up, since the tools, materials and skills needed are very basic. So, a really low-treshold-high-impact project for kids of all ages. I hope you like it. If you make a vibro-creature yourself, please post a pic of it in the comments :-)
Update Sept. 1st 2013: The scary vibrobots are now named Bibberbeest. And, I made a brain for them, so you can switch on a Bibberbeest with a standard remote control! I did a lot of workshops with kids, making Bibberbeests. Here's an impression:
- Tools needed:Small screwdriver
- Multitool, or:
- Needlenose pliers
- Cutting pliers
- Wire stripper
- Knife or firm sciccors
- Materials:Connectors (8 to 18 stubs for a creature?)
- 20-60 cm electrical wire (the kind used in the electrical wiring in houses, with a solid core)
- 2-12 cable binders, different sizes and colors
- Double sided foam tape
- An electric motor that runs on 1,5 Volt DC. I used these, from Farnell. Motors are expensive if you buy them by piece, so if you have to order just one, try to harvest one from discarded toys instead.
- 1,5 V AA battery
- AA battery holder
Costs:
Around €3,50 per beast if you have to buy a motor. Harvest a motor from junk toys and save €2,-
Time needed:
I make a bot creature in around 15 minutes. I didn't do this with kids yet, my guess is they'll need 45 minutes or so...
- Tips for making the bots:I fixed the battery holder onto the connectors with foam tape. That works well and makes the batteryholder removable.
- The black electrical wire fits through the connector when the screws are "turned up" completely. So, there's no real need to strip the wire.
- The previous makes it possible to wind the wire through a strip of connectors as a spiral. I did this with the creature in picture 5.
- The inside of a connector-stub comes in handy to make a "tail" on the motor shaft.
- To remove the inside of a connector, turn the screws loose and remove them. You can push out the connectors' inside-part easily.
Tips for tuning:
The creatures' movements are pretty unpredictable. You'll have to tweak and experiment to make the bots move the way you like. Experiment with just about any property of the creature you made:
- The length of your creatures "legs"
- The form and length of the motor's tail
- The added weight to the motor's tail (inside of connectors, a complete connector stub, etc.)
- The location of the battery and the motor: By replacing the battery or the motor, you change the distribution of weight. This has a profound impact on the way the creature moves
The new Lego: connectors, wire and cable ties
This is my third project that heavily relies on connectors, tieraps and wires as a "construction toy" (have a look at Blinky the LED pet and the Blinky Dragonfly). Wire, connecors and tie-raps are pretty generic and obtainable everywhere. The versatility of this stuff really amazes me! So this won't be my last connector-wire-tie based project :-)
Enjoy building Bibberbeests.
Step 1: Tools and Materials
- Multitool, or:
- Needlenose pliers
- Cutting pliers
- Wire stripper
- 1,5 V AA battery
- AA battery holder
Costs:
Time needed:
Tips for tuning:
UP! Contest
34 Comments
7 years ago on Introduction
I van build quite a few of these, guaranteed success with the kids! The hardest part to source are the motors, so here are few tips. If you have patience and can wait a few weeks, ebay is your friend, especially ebay.com.au. I just got these (the links will probably not work in a few weeks as the offer expires)
http://www.ebay.com.au/itm/301202968684 5 euro's for 5 high performance motors. Dirt cheap, and they run fine on 1.5V too. Also you can try finding cheap hand fans and scavenge the motor. http://www.ebay.com.au/itm/301202968684 which will set you back about 1.50 euro's.
It's also a great place for battery holders, usually 10 single AA or AAA for under a euro.
The rest I would recommend to source at your local DIY store. The cheap Chinese terminal blocks are too soft, too small, and their screws too dodgy to work well for kids. Not worth the difference in price, if any, IMHO.
9 years ago on Introduction
Easy to make and can be lots of fun to play with :D gonna try make some as soon as exams are over "_"
I want to order the parts for this but I can't figure out what those connectors are. Is there another name for them? What are they used for? Thanks.
I think they're called 16 Amp connectors, or terminal blocks. They're used for instance to connect lamp holders to electric wire. In The Netherlands, where I live, they're very common. Every hardware shop sells them for around €1,- for a 12-stud strip.
Hope this helps...
Here's a link to Farnell. They sell them for a crazy amount of money, but it might be useful for you to figure out what you need.
Thank you so much. That is a huge help!
9 years ago
Awesome! I have an instructable like this!
Hoi Ynze, Yesterday I made a nice Bristtlebot with my kids. My daughter calls him Frups. We used your instructions at slimme-handen.nl. After making it I just realized it was your site, haha. These are nice to, will be next project, and I might even make them with my class. Thanx! (And I pass the 3 months pro-membership to the next maker, I have enough pending pro memberships :-P)
:-) Cool! I like what you did with the switch! And Frups is a GREAT name!
I made a scary-bot with a switch yesterday, i'll post a picture shortly.
And it would be great if you can do this with your class! Will you post some pics then, please please please?
Off course I will, if I´ll get to some botbuilding. I´ve bought a 3D printer for the arts and crafts classes so that could make a nice combination, I think..
See the pics for Shakybot with a LED-tail and a switch. X'cuse me so much for the trashy pictures (made with my phone and horrible light :-)).
Hey, the combo with a 3D printer sounds promising! Maybe we should brainstorm on that one a bit more...
MMM, he looks familiar
All right, these look very nice!
(Ik neem binnenkort wel even contact met je op Ynze, lijkt me leuk een en ander eens uit te wisselen over mogelijkheden in de klas maar ook van Instructables i.h.a).
Love them !
You didn't see this one coming, did you ;-)
I sure didn't!
I made a second video (in slow motion). Your creature is in it :-p
:-) What is the name of the bot at 0:20 ? Kenny? :-)
Lol! From now on, he's called Kenny :-D. I was thinking to name them, so if you have more ideas...
:-) I have one more name for now: 0:47 Homer, because he heads straight for the edge of the cliff!! :-D Well done, they're cute little things! :-)
