Scrabble Tiles With Laser Cutter
Intro: Scrabble Tiles With Laser Cutter
This is just a simple file upload for scrabble tiles which you can cut out on a laser cutter. The idea is too spray paint them copper and glue them too oaken disks which i have cut from an oaken dowel. I have included the files for both an english and a Dutch set.
STEP 1: Straight to Cutting
Just use this above pdf to cut out your tiles on a laser cutter.
STEP 2: Gewoon Uitsnijden
Gebruik je pdf om je scrabbletegeltjes uit te snijden met een laser cutter
STEP 3: Paint
I'd suggest spray painting the tiles first. I've made them attached so they wouldn't fly away while spraying. I'll upload a picture when i get to do this
STEP 4: Cut Manually
Use an exacto knife to cut the tiles away from the skeleton.
STEP 5: Glue
Glue the tiles to a substrate of your choice. I have cut and sanded well over a hundred of these oaken tiles by cutting down a long dowel. I'll be using these to give the tiles some structure.
4 Comments
Alex in NZ 4 years ago
FarRighteous 4 years ago
seamster 4 years ago
