Introduction: Scratch Off Cards From Scratch!
Hey guys!
Everyone likes scratch off cards, so in this instructable I'm showing you different ways to make them from scratch! I promise they're just as satisfying to scratch as store-bought tickets.
- tape or clear plastic sheet
- glue stick / other glue
- paper
- scissors
- pens or printer
- ruler
- watercolors or acrylic paint
- paintbrush
Step 1: Acrylic Paint Vs. Watercolors
First, I wanted to test which paint works best.
Most DIYs that I have seen use acrylic paint mixed with dishwashing liquid, but when I compared it to pure acrylic paint, I didn't feel much of a difference.
I would go for one thick layer of pure acrylic paint instead.
But another option is using watercolors!
Watercolor comes off very easily, you barely need any pressure.
It is more dusty and less flaky. Optically it does look better and more smooth than acrylic paint.
All in all, I prefer watercolors, but it depends on the situation.
The disadvantage about using watercolors is that it can't be handled too much. If you want to make a more durable card that doesn't get scratched by accident, use acrylic paint instead.
Step 2: The Plastic Sheet Method
Now let's make a scratch off card!
For the first method, I'm starting off with a clear plastic sheet. You can find it in packaging or stationery supplies - basically anything that is clear and smooth should work! You can do a quick test if you want to be sure.
Next, you will need some paper. I used some card. Make the plastic and paper sheets the same size. Then you can write whatever you want on your ticket! You can also use a printer of course.
Step 3: Taping
To connect the plastic with the paper, you can either use nice looking tape, or you use normal tape and cover it up with paper (next step).
Step 4: Optional: Framing
I used clear tape, so I wanted to cover it up.
I cut some paper strips for each side and folded them in half. Then I used a glue stick to glue them in place and trimmed the excess paper.
You should end up with a framed card :)
Step 5: Making the Scratch Area
Now to my favorite part: Making the scratch area.
I used silver watercolor, but of course you can use any color you like. You can either freehand the paint, or you can make a border using masking tape.
And then you just need to load your brush with a lot of pigment. If the paint doesn't apply properly, you probably have too much water. Just swirl your brush around a lot and the paint should go on nicely.
After letting it dry for about 15 minutes, you can peel off the masking tape. Then you can do corrections with a toothpick and remove all the dust from your card.
If you want, you can also tape a coin to the card.. and you're ready to scratch!
Step 6: The Tape Method
Another option is to cover your design with tape. I would recommend to test your tape first, because I've had some that didn't work, but most tapes are fine.
This time, I'm covering my motive with watercolors first and I'm cutting it out lateron.
Tip: Sometimes it's better to dab on the paint instead of doing it in strokes.
Step 7: Cutting and Glueing
I used thinner paper so I could see where to cut it on the back side and cut out the symbols.
Another reason why I chose thinner paper is so I could see which side is the right side up when I glue on the symbols.
I used a glue stick again and was careful not to touch the paint too much - like I mentioned watercolors are more delicate.
And that's it! I am excited myself to use this idea for many occasions.
Hope you like it!
Sticky Stuff Speed Challenge
