Secret Compartment Frame
Intro: Secret Compartment Frame
Here is how to make your very own secret compartment frame.
STEP 1: Cut the Wood
First cut your 2x2 so that you have 2 10.5 in pieces and 2 17.5 inch pieces.
Next, using a table saw, cut a groove with 1/4 in depth in all four 2x2's.
Cut your MDF piece to be 10 7/8 in by 15 1/8 in.
For the backing you will need another piece of MDF that is 13 in by 17 1/4 in.
STEP 2: Glue
Place wood glue in the top groove, then place the MDF piece in.
Make sure that the MDF is centered.
STEP 3: Painting
This step is optional.
Paint your 2x2's and MDF using acrylic paint.
For the front piece of MDF, I used chalkboard paint, but you could also make this a frame for a photo, piece of artwork, or cork board. Which you could place on top of the MDF.
STEP 4: Putting It Together
Using a Kreg Jig, drill holes into the two side pieces, making sure that they are opposite.
Then, screw the two sides to the bottom piece using 2 in screws.
Test and make sure that the MDF can slide up through the sides. (If you are having trouble getting this to work, you can use some bar soap on the sides of the MDF to help it slide easier.)
Center the back piece on the back of the frame, and drill holes around, making sure not to drill into the top piece. screw the back on using 3/4 in screws.
STEP 5: The Inside
On the inside I used command hooks to hang things like necklaces or keys from, and small clothespins for money, tickets, or pictures.
STEP 6: You're Done!
You now have your very own secret compartment frame.
AnandM54 3 years ago
