Secret Key Hiding Spot
Introduction: Secret Key Hiding Spot
This is a easy hiding spot for your spare key or regular key.
Step 1: Gathering Supplies
The supplies you need are:
1. A key sized tin can
2. Rocks
3. Hot glue or glue that would work on rocks
4. scissors (POSSIBLY)
5. A shovel
6. An area in your yard with rocks
Step 2: Cleaning the Rocks
It is important to clean the rocks because if you don't, the glue might not stick to the rocks.
Step 3: Gluing the Rocks to the Tin
When gluing the rocks to the tin make sure you can't see much of the glue.
Step 4: Digging
After you dig the hole make sure the tin is a little under the rocks
Step 5: Placement
Put the key or other item in the tin
Step 6: The Last Step
place the lid on the tin and insert a few rocks around and voilà you have your self a key hiding spot.
Hiding Places Contest
Unusual Uses Challenge
Reuse Contest
Reuse Contest
Be the First to Share
    • Pumpkin Challenge
      Pumpkin Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
