Secret Safe Thingy
Intro: Secret Safe Thingy
It's a really simple secret safe thing that only works for cash but hides discreetly and actually works and can be made again really easily
STEP 1: Materials
You Need:
A tissue box
A pair of Scissors
Mauly Clip (Binder Clip)
Cash
A tissue box
A pair of Scissors
Cash
STEP 2: Step 1
Flip the box upside down and cut a hole in the upper left portion of the box and leave a part at least part of the size of the cash (see picture below)
STEP 3: Step 2
Fold up money in half and put it all in the Mauly
Put it into the hole in box and put it in the corner so it wont fall out (picture)
STEP 4: Final Step
Flip it over the weight of the tissues will hold the money in
If you run out of tissues just cut another hole in a different one
Done!
OMG to the people who were in the forums I'm so sorry I had a mad load of tests
Btw to compensate for myself being late I'm making another instructable that replaces
Belkin's Cushtop for a 2 dollars of less
Done!
28 Comments
Duct tape 101 8 years ago
LouiseMarie 13 years ago
glorybe 13 years ago
One method that seems to trick most crooks is to take a bedroom door off of its hinges and drill a hole in the bottom of the door. Insert your stash and then plug the hole with the right sized,round ,wood plug. This is for longer term security as it does make retrieval a bit slow.
Another trick is to install a phony pipe. Some closets have exposed vent pipes and a phony pipe that enters the ceiling and has a cit out in the floors surface is very convincing. It should be plastic and not copper as crooks do take copper at times.
star_above_the_clouds 13 years ago
ac1D 15 years ago
unmdec 13 years ago
Deltaforce2555 15 years ago
lightpacker 15 years ago
unmdec 13 years ago
maruawe 14 years ago
unmdec 13 years ago
NinjaSloth 14 years ago
mas9779 15 years ago
oniman7 15 years ago
It's a safe that goes inside the wall, and looks like a regular power outlet. Here's what they say about it: "An easy way to conceal your stuff
The Hidden Wall Safe is handy because most burglars spend less than six minutes inside a victim’s home and only have time to check the most obvious places for valuables. These unique wall safes allow you to hide valuables inside one of many identical looking wall outlets you already have in your home, the last place someone is likely to look. According to the Chicago Police these units are better than a locked safe and a hundred times cheaper.
Worried about the outlet cover not matching your other outlets? No sweat, you can interchange any standard plug cover for this one to match your other plugs.
High impact plastic and metal
Once installed it pivots out to reveal the secret hiding place
Comes with cutout saw and template for easy installation in just minutes
Dimensions: 7"H x 3.5"W x 2.5"D
Jewelry and money not included!"
For $8, I think it's worth it.
maruawe 15 years ago
joey2542667 15 years ago
LilJay0131 15 years ago
grundisimo 15 years ago
