Introduction: Self Carving Pumpkin
Tired of carving pumpkins? Have a large squirrel population in your neighborhood?
With a little guidance and a couple of days, they will do the job for you.
Required tools
Drill
1/8" or larger drill bit
smooth peanut butter
Required tools
Drill
Step 1: Drill Guide Holes
The drilling process can be pretty rough as it is difficult to control the accuracy of the squirrel's gnawing.
Start with an uncut pumpkin. You do not need to open it up and scoop out the guts. The squirrels do that for you.
Using a drill on low speed to reduce spattering, start out by drilling holes where you want the final holes in the pumpkin to appear. As shown in the first picture, I have drilled 1 hole each for the eyes, nose and a line of holes for the mouth. Drill all the way through the pumpkin flesh.
Drill around these holes to make the openings bigger as shown in the 2nd and 3rd photos.
Step 2: Fill the Holes
Using a knife, toothpicks and fingers, put smooth peanut butter into all of the drilled holes. Try and get it as deep as you can.
I have tried using a cake decorating syringe but it did not work particularly well as the peanut butter is too thick. And it ended up being more work to clean than to have carved the pumpkin in the first place.
Once all of the holes are filled, wipe the surface peanut butter off all of the places you don't want the squirrels to eat. Its OK to leave surface traces of PB on the areas where you want the holes.
Step 3: Place Pumpkin
Place the pumpkin outside in a squirrel-rich environment. The second picture is was taken after the pumpkin had been outside for 10 hours.
You can add a little more peanut butter to the pumpkin to direct the attention of the squirrels to areas you would like "carved" quicker.
The squirrels will eventually break through the flesh into the pumpkin and take away all of the seeds.
