Self- Driving Car
Intro: Self- Driving Car
1. This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com)
STEP 1: Step 1: Get Your Parts
You will need:
1 simple remote control car from like walmart
2 arduino UNO boards
2 9 V batteries
2 9 V battery connectors for arduino
1 small breadboard
6 IR sensors
3 transistors
about 30 connector cables, various sizes
arduino IDE
1 soldering iron and solder
1 box
1 velcro pad
STEP 2: Step 2: Soldering Connectors to the Remote Control Circuit Board
Solder a transistor with its B and C legs on either side of the front, left, and back pushbutton, on the underside of the circuit board. Then solder a jumper wire to each transistors E leg, and a cable to each transistors B leg as well. The jumper cable from the Es should plug into the + rack of your breadboard, and the cables from your B legs for the forwards and backwards into pins on your first arduino and the cable from the left into your second arduino. Because of the way the circuit board is set up you can only do 3 directions. And need to add a second microprocessor to do the third.
STEP 3: Step 3: Solder and Connect Your IR Sensors
Solder one jumper cable to each leg of the IR sensor, plug in the leg labeled VCC to the + on your breadboard, the GND to the - on your breadboard, and the out into a different pin on your first arduino. Place the 6 with on at each of the 4 corners of the box,a dn the other 2 at the front and back, and cut out holes and let the 2 bulbs sit unubtrsucted outside the box. Also tape down the sensors.
STEP 4: Step 4: Provide Power!!
Give everything power! Connect each 9V battery to its connector and plug them into the round port on the side of each arduino.
Take a jumper wire from your first arduino's +5V pin and connect it to the top of your breadboards + rail.
Similarly, take a jumper wire from your first arduino's ground pin and connect it to the top of your breadboards - rail.
Also, connect a jumper cable from one digital pin of your first arduino to your second arduino, so we can send a signal of when to turn left from the first to the second (since all the IR sensors are connected to the first arduino, the second cant read them).
STEP 5: Step 5: Write Your Code
Download and install the Arduino IDE, then write this code, and upload the first one to the first Arduino, and the second one to the second Arduino.
First arduino
Created by Patrick Tipaldo
Student at USF for makecourse fall 2017
Released into the public domain
int ir0 = 2; //each IR sensor
int ir1 = 3;
int ir2 = 4;
int ir3 = 5;
int ir4 = 6;
int ir5 = 7;
int ir0m = HIGH; // HIGH MEANS NO OBSTACLE
int ir1m = HIGH; //Ir measurement variable
int ir2m = HIGH;
int ir3m = HIGH;
int ir4m = HIGH;
int ir5m = HIGH;
int forwards =8; //high for forwards // these are connected to the cars controller
int backwards = 9; // high for backwards // we can send a voltage to circumvent the pusbutton and make it go. int left = 12; // low for left //connected to second arduino
void setup()
pinMode(forwards, OUTPUT);
pinMode(backwards, OUTPUT);
pinMode(ir0, INPUT);
pinMode(ir1, INPUT);
pinMode(ir2, INPUT);
pinMode(ir3, INPUT);
pinMode(ir4, INPUT);
pinMode(ir5, INPUT);
pinMode(left, OUTPUT);
void loop()
digitalWrite(left, HIGH); // initial conditions, when there is no obstacle just go straight
digitalWrite(backwards, LOW);
digitalWrite(forwards, HIGH);
delay(400);
digitalWrite(forwards, LOW);
delay(500);
ir0m = digitalRead(ir0);
ir1m = digitalRead(ir1);
ir2m = digitalRead(ir2); // read the IR sensors
ir3m = digitalRead(ir3);
ir4m = digitalRead(ir4);
ir5m = digitalRead(ir5);
if (ir0m == LOW)
digitalWrite(backwards, HIGH); // if top right detects obstacle, go back and left, unless an obstacle is //detected from behind, then go forwards
digitalWrite(left, LOW);
int i =0;
while ( i<2000)
if ((ir3m == LOW)|| (ir4m == LOW) || (ir5m == LOW)) //delay loop, just so we can continually check behind the //car
{ //3 is back left IR sensor, 4 is back, 5 is back right
digitalWrite (backwards, LOW);
i++;
if (ir1m == LOW) //front IR sensor
int i =0;
while ( i<3000)
i++;
if (ir2m == LOW) // top left IR sensor
int i =0;
while ( i<3000)
i++;
Second arduino
Released into the public domain */
int left = 7;
int right = 8;
int Ar1_left =4; // connected to first arduino which says when to go left
void setup()
pinMode(right, OUTPUT);
pinMode(Ar1_left, INPUT); }
void loop()
if (Ar1_left == HIGH) //if first arduino says to go left, then go left
delay(1500);
delay(500);
} //or else just dont
STEP 6: Step 6: Let Your Car Drive! Refer to Circuit Diagram for Help
Use the velcro pad to pad your box to your car, turn it on and watch it drive!
Also you can refer to the circuit diagram if you need help.
The car operates using the sticks to push down the pushbuttons. The pushbutton, when pushed , lets current flow across it, so we are bypassing this and providing a signal on either side of the pushbutton to make the circuit think that the button is pushed and that current is flowing.
To do this we connect a transistor to either side, and when we provide a high signal, current flows across the transistor, or either leg of the pushbutton. Everything else is just basic wiring and soldering.
You could also 3D print the box on top, however i decided not too, as i believed the additional weight would weigh down the car and make it unable to move. So instead, I simply used a very light cardboard box, which i spray painted black to look more proffessional, and poked holes for the IR sensors.
2 Comments
duynvgch17574 3 years ago
Chrome98 6 years ago
