Self Sufficient Arduino Board
Intro: Self Sufficient Arduino Board
This is a self sufficient Arduino board, which is powered by harnessing solar power and using a 9V rechargeable battery. It is perfect for anyone who is interested in doing Arduino projects that do not require a computer or any power supply. You can take this to the most remote places for any project.
What you will need:
9V Rechargeable battery
Solar cells (About 11V)
1N4001 diode
100uf 10V capacitor
Arduino board
9V battery connector
Power connector (to connect to the Arduino board)
What you will need:
1N4001 diode
100uf 10V capacitor
Arduino board
STEP 1: Setting Up the Arduino Board
This is probably the simplest step (please use the schematic as reference for wiring before doing anything else).
Change the jumper of the Arduino board to "EXT"
STEP 2: Understanding the Components
This step would require you to have a basic understanding of the components and their polarities. This is probably the toughest bit of the setup. For easier understanding, I have used red wires for positive and black wires for negative.
STEP 3: Getting the Power Connector Ready
Solder the positive and negative wires to the power connector as shown in the picture. The power connectors come in different diameters, so do choose the correct size to fit the Arduino board.
STEP 4: Wiring Up the Circuit
This shows the circuit I have soldered. I have made it bigger for easier understanding. It can actually be made much much smaller (half the size or even smaller).
You can download a more detailed document on this from my website at:
http://www.p2man.com/arduino/self_sufficient_arduino.pdf
You're done! Now you can break away from power points and even have Arduino projects out in natural environments without a problem.
61 Comments
easp1973 6 years ago
I have a 12V 150W pannel on my roof. Can I use this schematic also for it our the W is to high? I think it will generates 7A on its maximus.
PushkalK 8 years ago
The link is dead. Please update the link. Link the file with dropbox or google drive.
thpol 8 years ago
Shoud it need some sort of charging control? To protect the battery from overcharging or prevent full discharging?
Dasaradh M S 8 years ago
mohammadk 10 years ago
Thanks.
My Question is :
Solar Cell : 11 Volt . OK . But How Much mA ?
jcantuba 9 years ago
how big your solar call en because if you have 12v solar cell en it is 3.5 watt it can do up to 200mA
i made it up to 10 watt
Lucky7Gaming 10 years ago
Is there any way where I could replace the battery with a 12v AC adapter and still use the solar power mostly during the day and AC adapter at night?
diy_bloke 9 years ago
not sure if yr question is still actual,but the problem u havewith that is that the 12 v is higher than the 9 V from the solar power and thus in the current circuit, the solarcel would never be used. You would need to bring down the adapter voltage to about 8 Volt to do what you want
p2man 12 years ago
thesrikant 12 years ago
sprive 12 years ago
Adafruit has a tutorial on converting an Arduino Uno from 5v to 3.3v. There are loads of 3.3v Arduino designs about (including the awesome JeeNode, which fits in a medicine bottle and can last months on a boosted AA battery).
krowney 16 years ago
p2man 16 years ago
qwerty156 12 years ago
Lenny24 14 years ago
Greets
p2man 14 years ago
Yes it does "smoothen" the flow of electricity to the batteries, as the electric output from a solar cell is not always constant. Here is a link that might help you understand more on capacitors :)
LasVegas 16 years ago
prutschman 16 years ago
