Step 1: Wood Glue Composite Pieces of Wood Together and Hold With Vices
Step 2: Draw the Telecaster Shape From the Wood Using a Printed Layout
Step 3: Drill From Outside of the Shape (this Part Will Be Done With the CNC Machine)
Step 4: Remove the Excess Material
Step 5: Outline Routing of Components
Step 6: Remove Wood for Fretboard
Step 7: Order Metal and Electrical Components
Step 8: Test Fit the Neck and Make Any Necessary Sanding Adjustments With All the Various Sanding Methods in the Shops
Step 9: Route the Rest of the Cavities (this Will Also Be Done With the CNC Machine) When Finished, Solder and Screw Everything Together and Install Pickups
Step 10: Add Any Varnishes, Clear Coats, Stains, Etc. and Screw in Pick Guard in Adjustment With Rest of Components (example)
Step 11: Example of Finished Product (without Finishes)
