Servo Motor Control Via Bluetooth With Potentiometer
Intro: Servo Motor Control Via Bluetooth With Potentiometer
In this project, we will make the servo motor control with potentiometer via bluetooth.
Two will make the Arduino board via bluetooth wireless haberleştirerek control. Manages one of the modules for this (master) while the other managed (slaves) must be in mode. For both the master and the slave module settings, please click the link below.
http://www.robimek.com/hc-05-ile-hc-06-bluetooth-modullerin-haberlesmesi/
STEP 1: Materials:
- 2 Number Arduino (Nano enough)
- servo-motor
- 10k potentiometer
- Hc-05 Bluetooth Module
- Hc-06 Bluetooth Module
STEP 2: Transmitter Circuit:
Let's connect the signal pins to the analog potentiometer 0 pins.
Hc-05 Bluetooth module 4.p the tx pin, RX pin of the 3.pi to my tie.
STEP 3: Receiver Circuit:
10.pin let's connect the servo signal to the pin.Hc-06 module TX to RX pin of the pin 4.pin 3.pin to my tie.
STEP 4: Transmitter Software:
//Yazılım Geliştirme By Robimek – 2015
//Yazılım Lisans By Robimek
//www.robimek.com
#include <SoftwareSerial.h>
#define BT_SERIAL_TX 4
#define BT_SERIAL_RX 3
SoftwareSerial BluetoothSerial(BT_SERIAL_TX, BT_SERIAL_RX);
İnt potpin = A0;
int val;
void setup()
Serial.begin(9600);
BluetoothSerial.begin(9600);
void loop()
val = analogRead(potpin);
val = map(val, 0, 1023, 0, 179);
BluetoothSerial.print(val);
delay(100);
STEP 5: Receiver Software:
//www.robimek.com
#include <Servo.h>
Servo myservo;
Servo myservo;char val = ‘ ‘;
void setup()
Serial.begin(9600);
myservo.attach(10);
void loop()
if (BluetoothSerial.available()>0)
val = BluetoothSerial.read();
int servoAng = val – ‘0’;
myservo.write(servoAng);
STEP 6: Finally
After installing the software, you can manage your power engine now wirelessly via a potentiometer.
More Information: http://www.robimek.com/potansiyometre-ile-bluetooth-uzerinden-servo-motor-kontrolu/
14 Comments
TMPK 4 years ago
multiple servos with potmeters via bluetooth.
Keittiot 4 years ago
Kind regards
Tom
DavidF21 4 years ago
Please help
jmzagluba 5 years ago
I've been trying to this but with 3 servos to control.
Can anyone help me with the sketch?
Ive tried modifying it but there is always error.
I am a newbie and have no experience on C+ language.
Thanks
vipul.swamy 6 years ago
Hi there!! thanks for the tutorial. But my (BluetoothSerial.available()>0) is not working, there is no serial communication between my Hc05 and my Hc06 please help.Thanks
siddiqui_saad 7 years ago
muhammadd46 7 years ago
hc 05 bluetooth whether it could have sent some data sensors to control robot ?
if it supports , can to do?
AnkitG27 8 years ago
I AM USING ARDUINO MEGA AND TWO HC05 MODULES TO CONTROL A SERVO USING POTENTIOMETER, BUT CANT ABLE TO DO IT..
ANY HELP??
sezgingul 8 years ago
phamb587 in Receiver Software change "char" to "int" and in transmitter software change "BluetoothSerial.print(val);" to "BluetoothSerial.write(val);"
ohn Tan峻 2 HC-06 can not communicate. because only works in slave mode.
one master to be able to do well in slave mode of communication must be other
John Tan峻 8 years ago
Is this also apply on 2 HC-06?
phamb587 8 years ago
Hey Sezgingul!
Im using Board Uno connecting (HC-05) as master. And the other is Board Mega connecting (HC-05) as slaver. I also apply your code in both Uno and Mega, but I change the pin tx and rx
Uno
#define BT_SERIAL_TX 10
#define BT_SERIAL_RX 11
Mega
But nothing happens after I twist the potentiometer Can you give me some advices
Thanks
yes but can not using lm7805 to arduino power.
Volthaus Electronics Laboratory 8 years ago
I am surprised no has said anything about the amount of current the nano can supply versus the current the servo will require? I set up something similar with a servo turning a potentiometer. I used an LM7805 to provide the power to the servo.
