Settlers of Catan Support Board (For Under $10)
Intro: Settlers of Catan Support Board (For Under $10)
I will show you a cheap and easy way to create a playing surface to hold your tiles together and allow you to easily move your game.
STEP 1: Gather Your Supplies
**MAKE SURE YOU GET THE RIGHT SIZE FOAM BOARD!**
I first looked at Wal-mart and the foam board they had was too small. I found the appropriate size at Meijer.
What you will need:
1. Pencil
2. Foam Board x 2 (22in. x 28in)
3.Settlers of Catan Tiles
4. X-acto Knife (Cutting Matt)
5. Ruler
6. Glue or other type of adhesive
7. Soda cans or something to use as weights
STEP 2: Arrange the Tiles on the Foam Board.
Arrange 7 tiles in the center of the first piece of foam board. I arranged these length wise. I used a ruler to get the tiles equal distant from the edges of the foam board. In my example here, it was ~77mm and ~235 mm from the edges. I then applied the soda cans to keep the tiles in place. I then assembled the remaining tiles.
STEP 3: Trace an Outline Around the Tiles
Once I centered the tiles on the board, I then used a pencil to trace an outline. The cans add weight and help the tiles to stay in place while you trace the outline.
STEP 4: Finish Marking and Trimming Excess
I added additional lines to achieve an even border. I also drew sort of an oval to allow easy removal of the lid later. With all the marks made, I carefully used an X-acto knife to cut all the marks.
STEP 5: After Making Your Cuts
Once all the cuts are complete, you should have two pieces. The center piece you can save for later if you would like a lid for your board. The lid maybe useful for storage and transport.
STEP 6: Marking & Trimming the Bottom Board
I then centered the border piece on top of the second piece of foam board. Once in place, I marked the edges. I then trimmed off the excess from the second (bottom) piece.
STEP 7: Glue the Pieces Together
I then glued the border piece onto the bottom piece together. I used multiple cans to add weight while the glue dried.
STEP 8: Enjoy the Finished Product
Once finished you will have an inexpensive board to help keep your tiles in place while you play. Game on!
11 Comments
tatotosi 3 years ago
Bobby T 8 years ago
Damn, that's a cool way to store your game ! I'd love to see this decorate in the Catan graphics theme :)
xylophonic 11 years ago
infestacool 11 years ago
My set was the newer one mentioned above but I don't like the solid border as the pieces still move. This is great and solid. The expansion came with port tiles so it works well.
I'm considering cutting it and adding small hinges so it can fold like similar boards but I haven't made the jump yet.
jpople 12 years ago
Candor 14 years ago
lemonie 14 years ago
L
thirdspaced 14 years ago
L
jhines0042 14 years ago
Good work!
me 14 years ago
