Introduction: Sew a Louise Belcher / Bob's Burgers Hat
Louise Belcher!!!
I took a lot of formatting cues and the pattern design idea from...
Sew a Where the Wild Things Are hat + pattern! by jessyratfink
This hat isn't for me but I will freely admit that I have been wearing this for a couple of hours now and I am starting to feel uncomfortable without it!
If you see this embedded message.Build and then link to me for a 1 year pro membership. I have 5 to give.
Thanks Jessy for the inspiration!
I would love to see your completed hats. I am offering to give 3 month pro memberships to the first 3 who post pictures in the comments section!!! 3 might not be enough so I have more!!! keep on making and posting!!!
Step 1: Lets Begin!
tools include
- Sewing machine
- Scissors for paper
- Scissors of fabric
- pins
- needle for hand stitching
- pen
- cutting mat and rotary cutter
- Knitting needle
- needle nose pliers
- Armature of an appropriate sized head
Materials needed:
- Pink Polar Fleece
- Pink thread
- 20GA stainless wire
- Plastic Canvas
Download and print the attached pattern.
Note the attached pattern was modeled on an adult male armature as shown. you may have to adjust the cowl to get it to fit your model. adjustment explanation is in step 5.
Step 2: Pattern and Cut
The pattern itself is marked up as to where to cut and not to cut.
I sadly lack the penmanship of Jessy so if you have any questions please ask me for clarification.
Assemble the pattern as shown
This is then pinned to the fleece. you will require 2 from each side of the fleece. You will notice a texture difference and want to use the fluffier side of the fabric for the outside. I cut each these from a single layer.
I used a Rotary cutter and mat, this thing is awesome!
You will require 4 of each piece.
Step 3: Begin Sewing
Use the presser foot of the sewing machine as a guide along the edge of the material.
I set the machine to a shorter straight stitch for all seams.
The start and stop of all sewing is locked by going forward about a half an inch then reversing before going forward again.
Place two cowl pieces together with the fluffy side facing together then pin along the top curved edge.
Sew the cowl together along the top curved part from the peak to the base only.
Do not sew the lower or front edges.
Repeat for the second set of cowl pieces.
Place the ear pieces together in groups of 2 with the fluffy side facing one another then pin together around the edges.
There are two sharp angle cutouts at the base of the ears. Sew along from one cutout upwards then turn the ear as shown and sew the rest of the way back down to the other cutout. leave the space between the cutouts open.
Step 4: Prepare the Ears
You will need to turn the ears right side out, this is done from the hole in the base of the ear by working it with a knitting needle.
On a piece of plastic canvas, trace and cut the general ear shape.
You will need to make an ear support from a piece of 20GA stainless wire.
Cut a piece of wire about twice as long as the ear.
Thread the wire along the edge of the plastic canvas in a long weave as shown.
Feed the last 1/4 inch of wire through the canvas and bend and flatten it with a pair of needle nose pliers to completely blunt and fasten it to the canvas.
Repeat for the other edge of the ear leaving about a 4 inch loop of wire out of the ear opening in the base.
Gently coil the ear insert along the length and feed it into the ear opening.
The loop is then bent back at 90 degrees as shown.
This will provide the necessary support to keep the ear upright
Step 5: Prepare the Cowl
Note the pattern was modeled on an adult male armature as shown. you may have to adjust the cowl to get it to fit your model.
To adjust the fit, place a single layer of the cowl on your model and pin the front along the seam and the back along the seam. Pinning the front will bring the peak down and pinning the back will tighten the cowl.
Any adjustments will have to be done to both cowl assemblies.
With proper fit...
Place the 2 cowl halves together with the top seams centered and on opposite sides as shown. Pin along the edges being sure to mark and leave a 6 inch opening at the back.
Using the edge of the presser foot as a guide, sew along the entire edge of the cowl.
Leave the back open, remove the pins and trim along the edges of the seams in the chin strap leaving about an eighth of an inch.
Using a knitting needle turn the chin strap right side out then complete the turning of the cowl.
Step 6: Position the Ears
All sewing in this step is done from between the two layers of the cowl, through the opening that was previously left in the back.
You will need to cut a small incision in the outer cowl only. this is done in two places at the top as shown on the pattern. This cut is no wider than the base of the ear at its narrowest point.
Check for proper placement and adjust position as needed before you make the cut.
Note some of the pictures show a cut loop, DO NOT DO THIS!!!
Feed each ear into the cut in the cowl with the widest part of the ear flap facing away from the cowl center seam.
hand stitch the flaps against the outer cowl making the previously cut opening as tight as possible.
Repeat for the other ear then bend the wires back of the hat at 90 degrees to the ears.
The wire loops should overlap a little in the center.
Stitch both of the wire loops into the center of the top cowl seam, make this about an inch and a half long.
The loops should be left as big as possible for stability and adjustment of the ears.
Step 7: Finish the Hat!
With the cowl fully right side out, fold the rear opening inward and seal it with a top stitch.
Top stitch around the entire edges of the cowl, leaving a about an inch of no top stitch at the tips of the chin strap as shown.
The ears are adjusted by holding the wire loops flat at the top of the head and bending the ears as desired.
By the way I am still wearing it as I write this, it will be going to its new home soon. So I will probably have to make one for me in brown!
Halloween Costume Contest
Remix Contest
Teach It! Contest Sponsored by Dremel
Hand Tools Only Contest
19 People Made This Project!
- Spheni made it!
- objectivegiant made it!
- everydayicook made it!
- BigEMakes made it!
- Sucker4cats made it!
- lazerpandacat made it!
- SusanD8 made it!
- ValerieC52 made it!
- ymasullo made it!
See 10 More
39 Comments
Question 1 year ago
Hi, this is a nice pattern & written tutorial. Is there any chance of you making a video of this tutorial??
This video would help those if us that are hands-on learners.
Thank you Millions,
Genevieve
Question 1 year ago
I’m planning on making this as an every day practical hat to wear in all weather conditions. Do you have any suggestions as to what fabrics I should use for both outside and lining? And is there a heavy duty thread I could buy that isn’t too hefty? I’m very new to seeing and crafts so any advice will be awesome!!
7 years ago
if I made this with flannel instead of polar fleece or regular fleece would it look and work the same?? I'm on a little budget and fleeces can be quite expensive!!
Reply 2 years ago
Thumbs up on your question. I get too hot wearing hats so I want to use something a bit thinner than fleece, too.
Reply 7 years ago
You should be able to but keep in mind that the flannel will droop more. You may have to use bigger wire loops for the ears and sew the inner and outer cowels together along the top seam with the wire loops to keep the ears upright.
2 years ago
I've been looking for a "Louise's Ears Hat" pattern and this is the best one, and most accurate looking one I've seen. I haven't made it yet, but it's the one I'm going to use for my Halloween costume. Thank you very much!
6 years ago
how much fleece is needed for one hat?
Reply 4 years ago
I squeezed it out of half a yard.
Reply 4 years ago
If I mathed, -yes, mathed- it out right.. apx 3 sq ft
Question 4 years ago on Introduction
When making the stencils for an adult, what measurements did you use?
Question 4 years ago on Step 6
Hi - I need to make a pink BB Louise hat for a baby - I'm estimating between 13-15" head size - do you have a pattern in that size, or can you help me figure out what % I should print to achieve this, or any advise? Thanks
When printing this out, what did you keep it as? Did you print it out at 100% or at the 115%? Wanting to do this, but not sure of what percentage I should print this out on. Also, with the 20GA stainless wire, where did you find that?
Answer 4 years ago
Sorry for the delay... Use 100% as a base and adjust the zoom as needed to fit your head. The wire should be in the hinge or cabinet hardware isle of the local big box hardware store.
7 years ago
This tutorial was PERFECT! I finished my hat and it looks amazing. Thank you for the instructions!
7 years ago
Thank you for an actual pattern. Made one for my ADULT son last year and he loved it so much he wore it to a drinking event (he's 26!) and lost it on the train :(. So, for Christmas I'll make him another! Thank you thank you thank you!
Reply 7 years ago
You are welcome. I have another instructable set which is slightly modified. Check the related links at the right side of the page.
7 years ago
I'm making this for my dog. Hes going to be Louise for Halloween and my bf and me are going to be Gene and Tina. A lady at my work is making it for me. I'm going to use elastic at the bottom so i can stay on his head. (i hope this works) Thanks for the instructions
Reply 7 years ago
I would love to see the finished hat...
7 years ago
Making this for my Halloween costume this year. I'm new to sewing projects like this, so it might seem like a dumb question to more experienced sewers-- how can I make the lower part of the cowl and the chin straps more form fitting to my head? The crown/top fits nicely, but I dont like the way it flies out from either side of my face. I want it to mold to my head more like a beanie would. Any suggestions?
Reply 7 years ago
The pattern was done with general head size in mind. To modify, take the inside (closest to your head) two halves of the cowl and pin them together as you would for sewing. Fit them t you head without sewing and pin the from and rear seam s together to tighten up the fit of the cowl. Trim any excess off of the mid seem and repeat for the outer cowl halves. I hope that this helps...
