Sew a Zipper Pouch for Markers
Intro: Sew a Zipper Pouch for Markers
I use a lot of Sharpies and I got tired of having them loose in my backpack. They would always to the bottom and I could never find the color that I needed. So I decided to organize them with a simple zipper pouch.
In this Instructable, I'll show you how I made it for only a couple of dollars.
I made this at TechShop.
STEP 1: What You'll Need
For this project, you'll need the following:
- Fabric - I chose to use vinyl. You'll need a 8"x10" piece.
- Zippers - I purchased a 4-pack from the dollar store.
- Fabric scissors
- Thread
Since I'm doing this at TechShop, I'm using their basic sewing machine. You just need to supply the needles (which I also found at the dollar store) and you can check out a kit that has the feet and everything else you need for the machine.
Because I'm working with vinyl, I chose to use a #16 needle.
STEP 2: Setup Your Machine
Before beginning your project, check the settings of the machine to make sure the stitch pattern is the one you would like to use. I decided on a straight stitch with a moderately long stitch length. With vinyl, you don't want a short stitch length because it could weaken the material.
STEP 3: Sew the Zipper
I did trial and error a few times before finally figuring out an easy way to do the zipper on this bag. You may be limited by the sewing machine and which feet you have available. This method just uses the standard foot and should be simple enough to do on any machine.
- Lay your material good side up. Along the 8" side, lay your zipper face down. Roll the edge of the fabric over the zipper so that it's sandwiched between it, with the good sides touching the side of the zipper.
- Pin it to secure it in place
- Sew right along the edge, removing the pins before you get to them. Once done, go over it again so that you have 2 stitches on that side of the zipper.
- Repeat with the other side of material and other side of the zipper
STEP 4: Sew the Edges
Now that we have the zipper installed, we can sew the edges closed.
- Open the zipper completely. This is important otherwise it will be very difficult to do after you sew the edges.
- Make sure you're free of the metal zipper hardware and sew a straight line right down the sides. Again, double it up and run another right next to it to make it stronger.
- Repeat for the other side.
- If you have any part of your zipper that's remaining, just trim it away with your scissors.
- Cut each of the 4 corners at a 45 degree angle to remove excess fabric. This will make the corners less bulky when you turn it inside out.
STEP 5: Turn It Inside Out (or Outside In?)
Now go ahead and flip it around. Using a soft object, push the corners through. It should now resemble a pouch!
Test the zipper and make sure everything's working. Fill it up with your stationary items and enjoy!
4 Comments
craftclarity 9 years ago
Zippers can be a pain. I got in the habit of sewing a little bit of material over the end to act like a little hood, as an end-stop for the zipper. Works really well. I'll see if I can come up with a good photo for you
mad4littlethings 10 years ago
I'm glad you didn't get all fussy about the zipper. People often get intimidated by those darn things and miss out on sewing fun stuff! I liked your instructions and the photos were very clear. Also appreciated the directions to just trim the zipper if it was too big, although this doesn't work so well if the zipper is metal. (Anybody remember metal zippers besides me?) If your clear directions aren't enough to eliminate zipper--phobia, folks, don't forget about velcro (or any hook-and-loop fastener).
trev25 10 years ago
Twin Jalanugraha 10 years ago
nice work, thank you.
