Sheet Metal Roller
Intro: Sheet Metal Roller
I am working on a project for which I need to make a metal pipe by rolling 1mm thick sheet metal. I have researched online and not found easy way to make a tool. I spent some time and came up with 3d printing solution to make a sheet metal roller. I believe this is the 1st 3d printed sheet metal roller available in the internet. I have tested with 1mm thick sheet metal and it is working fine. Metal can be rolled based on the pressure applied by the two M5 bolts.
Youtube: https://youtu.be/3dJySXXvipE
STEP 1: 3d Printed Parts
Download and print the files from printables
- Left Plate - 1pc
- Right Plate - 1pc
- Middle Plate - 1pc
- Spacer small - 4pcs
- Spacer medium - 4pcs
- Spacer large - 4pcs
- Handle - 1pc
- Shaft1 - 1pc
- Shaft2 - 1pc
STEP 2: Assemble Body
- Insert 8mm threaded rods to left plate and screw them as shown in the images.
- Insert spacers and bearing in the order: medium spacer -> bearing -> large spacer -> bearing -> small spacer.
- Insert M8 Bolts -> M8 Washers -> middle plate.
- Insert M8 washer -> M8 Bolts.
- Insert Another set of spacers and bearing in the order: small spacer -> bearing -> large spacer -> bearing -> medium spacer.
- Insert M8 bolts -> M8 washers.
- Insert right plate and bolts and then screw.
STEP 3: Tensioner
Insert M5 bolt in to 3d print and add M5 bolts from top. These bolts are used to increase the tension on sheet metal to roll.
STEP 4: Assemble Shaft
- Glue some waste metal washers as shown in image using epoxy glue. This part helps to prevent 3d part from damage while rolling the sheetmetal due to pressure.
- Insert bearing in to the print and add the part to right plate.
- Repeat the process one more time to make for another side.
STEP 5: Handle and Lever
- Cut a groove on one side of the 12mm metal rod.
- Insert the rod inside handle and screw it.
- Add additional M5 nut, bolt, washer to handle.
- Insert 12mm metal rod from left plate to right plate as shown in pictures.
STEP 6: Final Product
Final product is ready. Please watch my youtube video to see in action.
