Shelf Speakers W/ipod Dock (Part I - Speaker Boxes)
Intro: Shelf Speakers W/ipod Dock (Part I - Speaker Boxes)
I got an ipod nano in November and since have wanted an attractive speaker system for it. At work one day I noticed that the computer speakers I use worked pretty well, so I headed to the Goodwill later and found a pare of ok computer speakers for $7, After dissecting them I had a little amp and two speakers.
STEP 1: Dissasemble Speakers.
Here I have taken the speakers apart. I picked up the leatherman at radio shack about two months ago. Unfortunately that was before I knew about the MAKE: version of the tool.
STEP 2: Speaker Design
I tried out Google SketchUp and had the basic design down for the speakers in about 30 min. I highly recommend trying SketchUp, very easy and intuitive.
STEP 3: Build the Speaker Boxes
I had some nice pieces of maple left over from a cabinet I built. The bottom and front are attached at a 10 deg angle. I later wished this had been 15 deg. to match the ipod nano dock angle. The hole was made with a 3" hole saw and a drill press. Later I rabbited the inside of the hole so the speaker would sit closer to the face of the front.
STEP 4: Speaker Box Sides and Horn.
I used a forsner bit to drill a 1-1/4" hole for the horn. A strait pcv union was painted black and epoxied to the horn hole. Note the burn marks around the speaker hole rabbit, hard maple and routers do not get along very well!
STEP 5: Speaker Nearly Finnished
STEP 6: Install Speakers
I didn't want any screws on the face showing and the speakers were recently damaged by a curious 5 year old so I used hot melt glue to install the speakers, this should make replacement easy if I find some decent replacements.
STEP 7: Test Speakers
I decided this was a good time to test everything out. I simply stripped the wires and twisted them together. Perhaps its only my imagination but they sound better and louder to me than they did in the plastic case. This is probably due to wish full thinking, nevertheless they sound great and look better than the original.
Up next will be an enclosure for the amp with a iPod doc built in.
38 Comments
zenergymusic 10 years ago
Just some thought's from a speaker/sound geek
If you buy one try to find one seperate from the power supply and get a good one, about 4 amp 12 volt in case your want to play with bigger speakers.
You can also find lower power and more basic amps based on this chip's design. Any how the amp and power supply run about 25 30 dollars and put most bigger amps to shame as far as sound quality and efficency. Really you did a nice job and I get a kick out of doing the same thing. hacking the good stuff out of cheaply executed designs.
ViperSniper 12 years ago
andybuda 13 years ago
pdlbooboo 14 years ago
mattyuke 14 years ago
Da Nugesta 15 years ago
Punkguyta 16 years ago
The Lone Hoot 15 years ago
Punkguyta 15 years ago
DYLEGO 15 years ago
evanwehrer 15 years ago
DYLEGO 15 years ago
abadfart 15 years ago
prototype2213 15 years ago
