Introduction: Shoebox Aircondtioner
So, is a hoot summer day ?Dont worry,make a airconditioner and will be better.
Step 1: What You Will Need
scrissors
aluminium foil
shoe box
some glue
plastic foil(optional)
Electric set-up
cooler(a big one)
Ac adaptor(9V)
switch
wires
Step 2: Izolation
Izolate the box with plastic foil.(glue it to the box)
Step 3: Izolation Part 2
Cut the aluminium foil in 4 pieces.
Step 4: Izolation Part 3
glue all the pieces to the plastic foil.
Step 5: The Pipe
Cut a pipe and make a nice sistem.The air will come out of the pipe.
Step 6: The Electrical System
You dont need a soldering iron.Just wire up the cooler to the switch and then wire up the switch to the AC adapter.But be careful with the + and - on the AC adpter.
Step 7: Almost Done
Cut a square in te carvoard box and mount the cooler to the box.
Step 8: The Big Finish
That's it.
CAUTION
Do not put the ice directly to the aluminium foil.Put it in a container and then put it in de air conditioner.
If you have any questions .... wright a comment.
Thanks.
CAUTION
Thanks.
