Shutdown Computer Using Batch File With Your Desired Time
Intro: Shutdown Computer Using Batch File With Your Desired Time
This kind of batch file will shutdown your computer automatically with your desired time..
Just follow the instructions..!
For this instructable you will need:
1.Notepad
2. CMD
STEP 1: Open Notepad.exe
1. Ctrl + R
2. type notepad.exe
3. Hit enter
STEP 2: Copy the Code
@echo off
title shutdown
color 0a
:confirm
echo Enter password ?
set/p "pass=>"
if NOT %pass%== myhack goto END
goto you
:you
echo Do you want to shutdown your computer? (y/n)
set/p "cho=>"
if %cho%==Y goto loop
if %cho%==y goto loop
if %cho%==n goto END
if %cho%==N goto END
:loop set /p firsth=Hour/s:
set /p firstm=Minute/s:
set /p firsts=second/s:
goto zen
:zen set /a result1=%firsth%*3600
:zen2 set /a result2=%firstm%*60
:zen3 set /a result3=%firsts% goto ace
:ace
set /a result4=%result1% + %result2% + %result3% echo %result4%
:abort echo do you want to abort? (Y/N)
set/p "cho=>"
if %cho%==Y goto END
if %cho%==y goto END
if %cho%==n goto shut
if %cho%==N goto shut
:shut
shutdown -s -f -t %result4%
:cancel echo Do you want to cancel? (y/n)
set/p "cho=>"
if %cho%==Y goto cancel1
if %cho%==y goto cancel1
:cancel1
shutdown -a
:END
note: remember the password is myhack
STEP 3: Edit the Password Whatever You Like:)
(from the code above)
@echo off
title shutdown
color 0a
:confirm
set/p "pass=>" if NOT %pass%== (Edit your password here) goto END
STEP 4: And Then Save As Myshutdown.bat
1. ctrl + s
2. save as myshutdown.bat
3. select all files
4. done!
2 Comments
dattatry 9 years ago
seamster 9 years ago
Nice, thanks for sharing this!
