Shy Mask That Shuts Up When It Sees People
Intro: Shy Mask That Shuts Up When It Sees People
It's sad that we have to wear face masks due to Covid -19. It's not a very enjoyable experience, makes you hot, sweat, nervous and of course harder to breath. There are thirsty times when you are urging to remove the mask but scared to do so.
What if the face mask could open up when in a safe environment, with no people around. So you can cool down and drink. But to make it safe again, the mask should be able to shut off when anyone is approaching.
STEP 1: Start From a Prototype
Since this is a wearable project, I started mocking up a cardboard prototype, this is the fastest and cheapest solution for the correct dimensions, etc.
STEP 2: How It Works and Part List
The plan is to use an Arduino Nano that read signals from 3 PIR sensors, if any sensor triggers positive, then it shuts down the door by controlling the servo, and lights up LEDs to tell which sensor is triggered.
Some parts I used:
3D printer
I used this one: https://amzn.to/3cfC9X1
https://amzn.to/3cfC9X1 (Amazon)
https://amzn.to/3cfC9X1 (Banggood)
PIR Sensor: HC SR 501 https://amzn.to/3cfC9X1 (Amazon)
Mini Servo: https://amzn.to/3cfC9X1 (Amazon)
Wire sleeve: https://amzn.to/3cfC9X1 (Amazon)
Water decal paper for laser printer: https://amzn.to/3cfC9X1 (Amazon)
Protoboard https://amzn.to/3cfC9X1 (Amazon)
DISCLAIMER: This list contains affiliate links, which means that if you click on one of the product links, I’ll receive a small commission. This help support me and allows me to continue to make instructables like this. Thank you for the support!
STEP 3: How PIR Sensor Works and Why It's Not the Best Sensor for This Project
Under the lens of the HC-SR501 sensor, there are actually 2 sensors and a comparator circuitry. It sends out HIGH when the 2 sensor readings are different.
So if the sensor is stationary, the background will make 2 sensors with same reading, when a person or object with heat radiation walks by, one of the sensor will read the difference, thus trigger the module.
However, if you install the sensor on a moving platform, the constant motion will trigger the module often because environment, even though there is nobody come across. Pretty much everything have IR radiation.
Though it's not the exact sensor to detect human, it works for the mask application, even makes it safer since it always false positive to keep it shut.
STEP 4: Designing the Mask
To cover the full 360 degrees around you, I picked 3 sensors, 2 on the cheek, and one on the back of head. The sensor has a 110 degree range so that adds up to almost a full circle.
2 white ball(lens) on cheek will be quite funny looking like a clown, so I started some rough sketches, for a sci-fi look. With that style in mind and earlier dimensions from the mock up, we can start 3d modeling
STEP 5: 3D Modeling
I used fusion 360, starting form the major parts and mechanisms, then adding more details for the sci-fi look.
STEP 6: Putting All the Parts Together
STEP 7: Electronic Connections
The connection is quite simple, a lot of 5V, GND and digital pin connections. Since the Arduino Nano has very limited power ports, I created my own expansion using protoboard and some pins. Just solder all the wires together to make a rail.
I also made a lot of connectors(turned out not necessary and caused a lot of trouble), at a time I made a 4 pin connector that I have to figure out direction every time. Later I updated them using the Poka-Yoki philosophy, which is make all the parts coming together in an only possible way.
STEP 8: The Code
Very straight forward coding, basically a condition loop. When any sensor is triggered, it shuts down the door immediately and lights up corresponding LEDs.
See code attached:
STEP 9: Future Improvements
Check how it works in the video.
There are 2 disadvantages of this design.
1. The sensor false positive problem, a better sensor or even camera with AI would make it more accurate.
2. I didn't put in effort to seal the mask properly, but had thought of how to seal the door area. I think the fish mouth could be a very interesting mechanism to test out in the future.
This is not by any means a perfect project, but hope this could be your inspiration or entertainment.
Thanks for watching and see you next time!
DesignMaker
http://youtube.com/chenthedesignmaker
50 Comments
Seppywawa 3 years ago
en2oh 3 years ago
I wear a mask all day. I'm also a medical doctor. If I have post nasal drip, by definition, it comes out the BACK of my nose, not the front! Sheesh. "post" op is "after the operation" "Pre" op is before.
As far as nasal congestion goes, the world is a different place when you work in a dust filled environment. This would not be an adequate solution - nor would anything but a mask designed for that purpose.
The reason I'm a bit cranky here is that the post seemed to take a swipe at masks in the context of public health and that is just plain wrong. Masks are not sufficient but are necessary to help address COVID spread. When coupled with physical distancing and ideally, with an effective vaccine.... the numbers go down and we begin to get back to normal! (BTW, the evidence does not support the idea that the current vaccine prevents infection in others. IT might prevent transmission, but we just don't know. What it does do for certain is reduce the severity of the disease you might catch)
Sorry for the tangent,.... :)
johndremmer 3 years ago
https://www.youtube.com/watch?v=EvM51oWq7xY
If you have any further questions, you may comment on them here, on the video, or email me at JohnDRemmer@gmail.com
gmartonic 3 years ago
raogauravpalsingh 3 years ago
RedHandedJill 3 years ago
rossemo 3 years ago
sheila.wallace.737 3 years ago
mrsowlsclass 3 years ago
MidnightDave 3 years ago
Like you illustrated with the basic PIR concept, you were "half right".
The PIR sensor is indeed actually 2 sensors side-by-side, and the idea is that "motion" in front of the compound "eye" lens, will cause a hot spot to move between the two targets... So what we are looking for is a transition pulse pattern between the targets right? And in theory, the static background heat will set the base bias level on both targets...
Works great until... yeah, you move the sensor because now the entire background becomes a rapid series of transitions across the two sensor elements. So basic false positive trigger isolation is done on the daughter board with the 1-2 switch, meaning how many LR or RL (vs LRLR or RLRL) target transitions are required to send a "triggered" output.
So first mitigation is pulse counting off of all of the sensors. And second is to take the outputs right from the sensor vs the daughter boards. (get the actual pulse behavior from the sensor)
Side benefit is that you are getting a cheap IR gyro element behavior. Think like the scroll wheel in a mouse, if ALL of your sensors are showing a pulse pattern RLRLRLRL from the sensor elements, then obviously your are rotating the whole unit. The trick at that point is setting tolerance in the code to evaluate the buffers to determine if indeed this is a global change.
The other trick might be to incorporate an actual gyro sensor to give an actual reference to the design on "dampening" response.
All in all, love the project! It reminds me of hardware projects for robotics in the 80's!
sanjayb48 3 years ago
Daeras 3 years ago
I think the sensor behind you is a good idea, but for the front, a manual trigger would probably work better and maybe an override for when you stick a straw in there.
What about small cameras with recognition software like they use with security cameras which track people.
Just some thoughts.
As an alternative idea, what about a vented mask, you use a filter cartridge and a little fan that keeps on venting the mask to keep you cool and to overcome the filter pressure drop.
snowf7 3 years ago
I live in Canada and our Prime Minister recently did a public announcement telling us that we need not wear a mask unless we are infected. He said that it will not help to control the spread of the virus if healthy people wear masks. (Check the speaking "moistly" report) If anyone has heard differently in your country, please let me know. Thank-you.
e0142494 3 years ago
snowf7 3 years ago
stumitch 3 years ago
snowf7 3 years ago
cndlaugh 3 years ago
mgettles 3 years ago
