Simple Battery Spot Welder
Intro: Simple Battery Spot Welder
As part of an electric bike project I needed to weld 70 18650 Li-Ion cells together. I could have just bought a battery welder but where's the fun in that? This is my build. Nothing complicated and it didn't need to last too long.
STEP 1: Parts List and Tools Needed
Parts:
- Momentary push button
- Car starter solenoid
- Copper nails
- Heavy-duty cable
- 60A choc-block
- Timer relay circuit
- 3/4" MDF board
- 1" x 2" pine batten
- 10mm x 2mm steel bar
Tools:
- Screwdrivers
- Drill
- Soldering iron (60W+)
- Solder
STEP 2: Wiring Diagram
This is the circuit we're going to make.
The timer relay can be set to be closed for 0.15s when the button is pushed. This in turn fires the starter solenoid, which allows current to flow down the electrodes, creating the weld.
We could do without the timer relay and just control the weld by varying the time we press the button for but it gives a lot more control.
STEP 3: A Solid Base
We don't want the battery floating around the workbench so we need to construct a solid base for it.
Take some 3/4" MDF board and cut it to be 4" wider than the battery and about 4 times as long to give a good welding area in front of the machine.
Cut some 1" x 2" wood and screw it to the board to form the area where the battery will sit.
STEP 4: Mount for the Button
Add some more 1" x 2" on the top of the enclosure we just made and cut a hole in it the same diameter as our firing button.
STEP 5: Mount the Button
Mount your button in the hole we just made and feed the wires out of the bottom.
STEP 6: Test Your Circuit
Wire everything together as shown in the previous wiring diagram and test fire it, making sure that both the relay and the solenoid fire as expected.
STEP 7: Mount the Solenoid
We don't want the solenoid floating around so take some of the 10mm x 2mm steel bar and drill 2 holes in it. This will serve as both the positive contact and a solid mount.
STEP 8: Electrodes
Take two of the copper nails and cut the heads off them. These will be inserted in to the choc-block to form the electrodes.
STEP 9: Main Wires
Cut down some of the copper cable and mount some choc-block on the end. Insert the copper nails in to the other end and bend the wires until the electrodes are vertical and the wires are horizontal.
Screw one wire to the -ve terminal of the battery and the other to the output of the starter solenoid.
STEP 10: Test
Grab a battery you don't care about and test it.
You will need to experiment with how much pressure to apply to the electrodes but with a little practice you will be able to do a consistent weld.
I used this welder to build the battery for my electric bicycle: https://www.instructables.com/id/Convert-a-Full-suspension-MTB-in-to-a-Go-anywhere-/
11 Comments
dyinjm70 4 months ago
tinkker 1 year ago
Ad5000DOnnell 5 years ago
I built my own and was just wondering about the relay it turns off after like 1.5s which is too much time and I’ve changed out the jumpers to the shortest time and turned the knob as far as it could go I was just wondering if you or anyone else was having this issue as well?
microwattbott 4 years ago
Another work around is to measure how much 12V current is needed to hold the starter solenoid closed, then select a resistor (of the correct wattage) to limit the current. For example if the coil needs 200 mA, the R would be 12/0.2 = 60 ohms with a power rating of 2*W = 2*(12*0.2) = 4.8 watts or more. Easy way to do that is six 10 ohm 5 watt ceramic resistors in series. Of course if you can find a 60 ohm 5 watt then just use that. The next task would be to experiment (or calculate) to determine what size Cap. (minimum rating 25 V ) will get to the point of 66% filled in the target time of 0.1 sec (estimate) when being filled at a 200 mA rate. The thing to bear in mind is that the holding current for the coil is LESS than the current required to close the contacts. As the Cap. fills the current is dropping and quickly falls below the holding current and the starter switch pops open - spot weld completed, hopefully. Everything is in series on the control side PLUS a discharge path (a diode and large R [12V/50mA=240 ohms minimum] in series with each other and Parallel to the Cap.) is needed for the Cap. so it can reset and be ready for then next button push. SEE THE LINKS BELOW
https://electronics.stackexchange.com/questions/166904/understanding-this-simple-circuit
https://www.taydaelectronics.com/resistors/5w-resistors/resistor-10-ohm-5w-cement.html
Might be fun and profitable to use a modern LED for the drain diode on the Cap. That way you know the spot welding system is ready when the LED fades to dark. It is a Visual feedback.
https://electronics.stackexchange.com/questions/366147/are-leds-better-than-we-think
altosoarus 4 years ago
Mike Albuquerque NM
pmb6552 4 years ago
pw1972 4 years ago
jph99 4 years ago
Cheers JP
Global montage 5 years ago
note :The picture shows how our poles look when they are put up in the garden
https://globalmontage.dk welding company
https://global.hegn.dk the company we are makeing the garden fence posts to :)
Mikel99 5 years ago
DIY Hacks and How Tos 5 years ago
Nice. Thats a lot simpler than a $200 welding machine.
