Simple Blinking LED Circuit
Intro: Simple Blinking LED Circuit
A very simple circuit that you can build to blink or flash LEDs. The circuit is built using transistors, resistors, capacitors, and LEDs. Of course you will need a breadboard, wire jumpers, and a power source. The parts list includes:
- PNP Transistor, P/N 2907A, qty: 2
- Resistor, value 470 Ohms, qty: 2
- Resistor, value 100k Ohms, qty: 2
- Capacitor, 10 uF, qty: 2
- LED, Qty: 2
- Breadboard
- Jumper wires
Let's get started:
STEP 1: Add the Transistors
Add the two PNP transistors and the jumper wires from the power BUS to the emitter of each transistor. Because of the way I inserted the two transistors the emitter is on the left side of both transistors.
STEP 2: Add the Capacitors
Connect the two capacitors to the circuit. Connect the positive lead of the first capacitor to the collector of transistor 2. Next connect the negative lead of the same capacitor to the base of transistor 1.
Repeat the above process for the second capacitor. Connect the positive lead of the second capacitor to the collector of transistor 1. Connect the negative lead of the same capacitor to the base of transistor 2.
STEP 3: Add the 100K Resistors
Next connect the 100k resistors to the transistors. One lead of the resistor connects to the Base of the transistor, the other lead connects to ground. Do this for both transistors.
STEP 4: Add the LEDs
Finally add the two 470 Ohm resistors along with the two LEDs. I added a picture of a transistor to identify the Emitter, Base, and Collector.
Connect one wire of the first resistor to the collector of transistor 1. The the other resistor wire then connects to the positive wire of the first LED. The negative wire of the LED is then connected to ground.
Follow the same steps for the other resistor and LED. Connect one wire of the second resistor to the collector of transistor 2. The the other resistor wire then connects to the positive wire of the second LED. The negative wire of the LED is then connected to ground.
STEP 5: Supply Power and Watch the LEDs Blink
The last step is to supply power and watch the LEDs blink. I use a 9 volt battery and it worked fine.
For fun you can try other capacitor values to change the rate at which the LEDs blink.
76 Comments
Pipa String 1 year ago
tmichlovitch 1 year ago
Yodi 1 year ago
Yodi 1 year ago
prathameshchandekar7081 1 year ago
stoloui 1 year ago
DavidM681 1 year ago
ChrisRC 2 years ago
Thank you.
keerthan r 2 years ago
tmichlovitch 2 years ago
anivia2409 3 years ago
2 x 50V 10uF capacitors
2 x PN2222A transistors
2 x 330 Ohm resistors (I dont have 470 ohm so I used 330 ohm)
2 x 100k Ohm resistors
1 x 9V battery
Please help with diangosing it :(
tmichlovitch 3 years ago
phranki 3 years ago
power, so it could come on at night ?
phoenix98604 3 years ago
Gina_ex 3 years ago
1). Can this cct be expanded to make a design like a mini ( 6 - 8 ) multi-color LED Christmas tree ?
2). Would this - or a modified version - be programmable for random interval flashing of the LED's ,and if so what added components are required ?
What alternatives for power source are recommended, if any ?
This is not programmable. If you're interested in programmable circuits definitely check out Arduino, Raspberry Pi, and others.
Quoc Quyen 3 years ago
Vivian N 3 years ago
tomatoskins 9 years ago
These look awesome! Electronics are great! I've never thought to use this type of circuit before.
