Introduction: Simple Comic Wall Displays
About: Where to start, love getting creative and making new things and reusing old things for projects. Ive made 4 Ironman suits and always looking to make and design new randon wall pieces Always happy to chat abou…
Welcome to my 2nd expendable
While having a sort out I decided use some of the old bits of wood around the house to make some very simple but effective comic book wall mounts
Step 1: Items Needed....
For this job I cut a few corners to save time and luckily it didn't go wrong lol
You will need wood any will do I used a long 1m strip 3cm width 1 thick and had an extra 1cm x 1cm strip ( so 2 strips in total )
Hand saw
No more nails or strong wood glue
*Drill and nails for mounting on wall I cheated and used no more nails again to save making holes so these aren't required but each to their own
And obviously a few of your favourite comics
Step 2: Cutting
I roughly measured out 7cm along the strip and marked off where I needed to cut
I did this with both pieces
Then cut the measurements to what I needed and then continued until I had used all the wood
( you can use any thin wood for this as you will see from the pics it is very very simple )
Then I simply took one from each pile and glued then together like to see in the pics ( if you use 2 of the same size and width just glue one to the end of the other ) It's so simple even I did it lol )
Step 3: Wall Mounting
Now this part is super simple
My way I just added a small amount of NO MORE NAILS to each side and firmly push it to the wall where I wanted the comic to be displayed
Hold for a few seconds and it 'should' take hold itself
Leave to dry for a hour or 2
There will be some who say this what about removal, well I have done this before and they hold firm but a simple good tap with a hammer will take them off the wall and should not require a lot of patch up just a simple re paint ( no filler or messing about with screws )
Step 4: Pick Your Favourite Comic and Enjoy
Once dry simply put your comic in and your done
Hope this helps everyone feel free comment
Shelving Contest
Shelving Contest
