Introduction: Simple Delicous Turkey Legs
A homade Simple But Delicous Recipe for turkey Legs. :) You want to preheat the oven to 350 before starting this.
Step 1: Things You Need
1. turkey Legs most important thing you can't make this without them
2. Salt (1/5 tsp.)
3. Garlic Powder (1/6 tsp.)
4. Ground Black Pepper (this one varies depending on how much you like)
5. Season Salt (1/4 tsp.) (you can use Season All if you can't find Season Salt it'll taste about the same)
6. Limon 1 (optional)
7. Heat up the oven to 350 before seasoning
8. 2 hours of spare time (watching tv Esc.)
Small update here, if you want you can mix all the above ingredients in a bowl (besides the Limon) and then just spread it evenly on all the turkey legs. By the way the measurements here are for only 1 turkey leg, if you going to make more then follow the steps on the next page.
Step 2: Time to Season
Allright to make it easier then it is im gonna make you a list in wich order you follow.
1. Lay turkey Out on a baking pan like below.
2. Lay Turkey in the pan Doesn't have to be like mine as long as it fits.
3. Sprinkle some salt on them about 1/5 a teaspoon each (spread evenly on the Legs as seen below)
4. Spread garlic powder on then evenly like the salt about 1/6 a teaspoon each
5. then pepper a few good shakes depending on how much you like.
6. Season salt Use about 1/4 a teaspoon for each one
7. add enough water to make it about 1/4"-1/2" inches deep in the pan
8 Cover with foil
Step 3: Cooking Time!
Stick Your Foil Covered Turkey Legs in the oven at 350 degrees (By The Way don't change the temprature they cook at this heat the whole time) for an hour. take them out and Remove the foil. They will look like the picture Below. Turn them around and use about 2 quick dashes of each ingriedient used before (Salt Pepper Garlic Powder Seasoned salt Limon) If you used limon (which I did not) then put about the same amount on this side as well (1 lemon) if you like and have the "know how" you can save the broth (the water left after cooking) to make a tasty gravy if I have time I might make an instructable on this in the future.
Step 4: More Cooking
now Leave the Foil off and cook for another 1 hour uncovered (with the side you just seasoned turned up still). When you take them out they should look more or less like this. Now turn them around again (don't worry no more cooking) and let them stay like that about 10 minutes. Then serve em up with Mashed Potatoes and gravy and your other favorite side dish
1 Person Made This Project!
- TaraM12 made it!
50 Comments
Question 1 year ago on Step 1
It looks yummy :-)
I would like to try it but I have 3 huge (14oz each) turkey legs.
What would be the recommended cooking time?
Reply 1 year ago
I apologize that this is 5 months late, my email provider changed and I completely forgot to update my instructables (as you might imagine seeing as I have only ever posted 1....) Yes this recipe will work, however I suggest you double the listed seasoning recipe and just generously season them on both sides. save whatever you have left for chicken, burgers, and or even certain cuts of fish; or just throw it out as I don't imagine you'd have to much left over. My only other suggestion would be to use a food thermometer to be certain your turkey is fully cooked as the times listed here may or may not be suitable for that size (I lean towards the idea they will be cooked but better safe than sorry)
Question 4 years ago
Can you use chicken broth instead of water?
Answer 3 years ago
Yes. My experience has proven to use low sodium broth as to not have salty drippings for gravy.
If lazy, add a jar of low sodium turkey gravy to the drippings and you’re done.
4 years ago
I've probably made this at least 10 times now, always fantastic. Always brown. So those of you who are complaining about that...go stick your head in gravy..
Hehhee
5 years ago
Trying it
5 years ago
How do you make gravy from the broth?
5 years ago
If you add water as stated in this recipe...you will NOT get any browning of the turkey legs at all! Period. Adding water simply cooks the turkey by steaming the meat. Instead..place turkey legs in a lightly greased pan and cook at the stated temperature....but forget the water!
Reply 5 years ago
I beg to differ, mine came out (both times imade them) beautifully browned.
Reply 5 years ago
Respectfully ive made this or very similar variants of my recipe for years and i never have had an issue getting the browning that I show in the picture. I personally use water to help cook with steam which in my experience helps the drumsticks not dry out and you dont have to be concerned if its going to be fully cooked when yoi cool it this long of a time especially for those of us without a thermometer. :) in any case while I disagree thank you for the comment feedback is appreciated
5 years ago
I'm not the type to leave any sort of comments on anything.. but I have to say you've made cooking turkey not so daunting for me! So, thank you very much.
I'm making drum sticks so I can get the meat and make sanwhiches out of and the fact the water helps cook it means the meat won't be dry.
Reply 5 years ago
If you make and end up enjoying this recipe let me know :) hope it all comes out well
5 years ago
Hands down, best recipe for turkey legs I've ever tried...and I've tried plenty! I followed the instructions and got the most tender, flavorful legs that went beyond my wildest expectations! Thank you!!
Reply 5 years ago
Hi Dreamingfree im honored to have authored this simple recipe that so many have enjoyed, and what has become the best you've eaten. I hope you had a merry christmas, and a soon to be happy new year.
7 years ago on Introduction
I bake chicken drum sticks the similar way all the time (380F (higher temperature means quicker, I have no patience), 20 minutes each side), never tried turkey drum sticks which in your picture surprisingly look the same as chicken drum sticks.
Reply 6 years ago
Turkey drumsticks are usually double or triple in size compared to chicken drumsticks.
7 years ago
Sounds good just bought some turkey legs!!!
I make this and I love it! Sometimes I make it with Mexican seasonings, other times French herbs and even curry form Jamaica. Oh so yummy
I've made this several times and it's perfect every time. Like keren.falkie I add olive oil, but otherwise follow the recipe and it never fails. Thank you so much for it!
I've made this several time already, it has become a true favorite. So yummy! I definitely recommend not skipping the lemon, it is my favorite part and what I think makes this a standout recipe. I do use a little bit of olive oil or butter on the turkey legs before putting in the oven.
