Simple Electrical Remote Switch
Intro: Simple Electrical Remote Switch
In this Instructable I show you the easiest way to make a remote switch control that will make it easier to turn stuff on and off when needed.
STEP 1: Gather Supplies
Gather all supplies listed below.
Supplies:
· Power Cord 14 Gauge
· Male Power Cord Adapter
· Metal Outlet Box
· 1/2” Knockout Cable Clamp
· Outlet/Switch Combo
· Outlet Cover
Equipment:
· Screw Driver
· Wire Cutters/ Strippers
· Needle Nose Pliers
STEP 2: Knockout Hole
Make a hole in the top of the metal box by pushing the screwdriver into the knockout. Then grab the edge of the knockout and twist with needle nose pliers to break the knockout completely off.
STEP 3: Wire Clamp
Attach the 1/2” knockout wire clamp to the electrical box.
STEP 4: Strip Wires
Next, strip down the wires on the power cord down from the end that will be attached to the outlet.
STEP 5: Power Cord Through Knockout
Feed the power cord through the knockout.
STEP 6: Jumper
Cut a piece of wire off of the end of the power cord Approximately 3”, and it will be used as a jumper on the outlet/switch. Next attach the jumper to the right side of the switch to the right side of the outlet.
STEP 7: Wire Outlet/Switch
From the power cord attach the Neutral “White” wire to the neutral terminal next to the outlet. Then attach the Power “Black” wire to the power terminal on the switch “Same Side as the Neutral. Next take the jumper wire and attach it to the other side of the switch to the other side of the outlet.
STEP 8: Attach Outlet to Box
Next screw the outlet/switch to the box and attach the outlet cover.
STEP 9: Tighten Knockout Clamp
Tighten the knockout clamp around the power cord.
STEP 10: Attach Male End Plug
Strip the wires on one end of the power cord and attach it to the male end of the plug.
BeachsideHank 6 years ago
This type of equipment may seem simple to many, but it actually encompasses some interesting aspects about the current state of affairs with the component parts. First the plug, it relies on the ground prong to support it whist tugging and pulling, if it is equal to or less than the length of the feed prongs, it will fail miserably at this vital role, look for one with the longest "barb". The combo switch and receptacle; I will not buy ones of contemporary manufacture, they are poorly made and even a once respectable name like Pass and Seymour are made offshore and not to the same quality standards of old. I hunt for these in thrift stores and buy those that state USA on them, also too I only pay $.50 to $1.00 for them vs. $8.00 at the box stores.
Any repair minded person should have one of these, it really helps in safety and troubleshooting.
