Simple Life Hack! Give Your Ugly Yellow Switch Board a White & Shiny Look
Intro: Simple Life Hack! Give Your Ugly Yellow Switch Board a White & Shiny Look
White color of Switch Boards Often turns yellow due to Sun heat/Dust & other weather Conditions.You can easily give these Ugly Yellowish Switch Boards a new Look.Whole process only requires 1-2 Minutes.
Hope you like the Idea.Please do comment in case of any further clarification required. Note:Always Turn Off main Power of your Home before doing any work at Switch Boards for safety purposes.
STEP 1: Required Tools
Tools required are...
1) Only a 150 Number Sand Paper is required for this DIY Project
STEP 2:
if your Switch Board have a front Cover.Remove it for better Access .
Now Start Rubbing it gently with Sand Paper No# 150. You can easily get this Sand Paper from Any Hardware Store.
STEP 3:
You can see white Color appearing after a little rubbing.
Carefully Rub Corners & Tiny areas to remove yellow spots.
STEP 4:
Half of the job is already done.
Front cover is also rubbed half to show the Difference,
STEP 5:
Here is the Final Look after Entire Switch Board is rubbed smoothly with Sand Paper.
Hope you like this Simple & Easy Idea. You can watch Complete You Tube Video Below.
Comments are more than welcome.
Stay tuned as more simple projects are coming soon.
Good Bye
Nazim Khan
2 Comments
Swansong 7 years ago
Good life hack, it looks much more neat :)
nazimkhan787 7 years ago
Thanks Swansong....
i was going to change these Switch Boards earlier,but a little effort save me couple of Bucks...
