Simple Mob Farm
Intro: Simple Mob Farm
In this Instructable, I will show you how to build a simple, starter mob farm.
STEP 1: First Farm
Start by making a 26 high block pillar
STEP 2: Channels
Make a cross with 7 blocks on each arm.
STEP 3: Levels
Add the secondary spawn levels
STEP 4: Spawning
Add the primary spawn level,the water and the signs.
STEP 5: Walls
Add the foundations for the walls.
STEP 6: Building Higher
Add the second level to the walls. Make sure they look like the ones in the photo.
STEP 7: Taking Cover
Add the roof and you are done!
77 Comments
burntcowz 1 year ago
supremetacos123 1 year ago
gavthelegoman 3 years ago
billeokello5 1 year ago
TBBAK 1 year ago
Instead of making a tower, try building the mob farm at ground level out of dirt blocks (much easier to get with a shovel). Don’t bother making the tower section. Instead, dig the 4x4 pit in the ground, and make it 26 blocks deep. Place some hoppers and chests at the bottom. Then you can tunnel down and make a small room where you can collect items from chests.
Not sure if this would affect spawns or anything. Is there a specific reason it has to be an elevated platform?
Tip: Build this on a mountain.
Pros:
Easier to build, because cheaper materials
Harder to die from fall damage
Less blocks needed.
Cons:
Might spawn less, since it’s untested.
Some advice gathered from comments:
Place torches outside and on top of the tower.
Try staying or mining somewhat close to the tower, so the mob spawn frequency is increased. Just build it somewhat close to your base.
Also never dig straight down.
Crafter1578 2 years ago
SaltyBadger9500 2 years ago
thebeastthomasxd 2 years ago
lmattingly5252 4 years ago
lvl30dragonenchanter 2 years ago
KittyAbbott3 3 years ago
ethandw94 3 years ago
u9000 3 years ago
A name 4 years ago
unOriginal26 3 years ago
If you do DONT, because mobs wont spawn if you are near them
If not then sorry i couldn't help you
Carleigh.Williams 3 years ago
