Simple Motor Bike Indicater Flasher Unit in a TIC TAK Box
Intro: Simple Motor Bike Indicater Flasher Unit in a TIC TAK Box
This is instructable assumes the reader to be compident in soldering. Use a very low resistance Mosfet ideally 0.2ohms or less and acurrent capability above 10 amps (the greater the current capacity the less need of a heat sink I used a 60amp continous current transister).
Changing the value of R3 will change the flash frequency. The Battery, Lamp Flasher circiut and switch are all in Series and therefore can be put in any order.
PARTS
Strip Baord
1 x Hex MOSFET transister N channel (min rating 3 times bulb current)
1 x PNP transister
22 awg wire (shorting links)
18 awg wire to connect to power lamps and switch
220K Resister
22K Resister
6K8 Resister
1n4001 Diode
100uF Capaciter min 25v
10uF Capaciter min 25v
TIC TAK mints packet
Insulation Tape
TOOLS
Solder
Sodering Iron
Craft Knife
Snips
Saw
PARTS
Strip Baord
1 x PNP transister
220K Resister
22K Resister
6K8 Resister
1n4001 Diode
Insulation Tape
TOOLS
Solder
Sodering Iron
Craft Knife
Snips
Saw
STEP 1: Biuld the Circiut
This circiut is very simple and can be made on a small piece of strip board.
Note The tall components (transister and Caps) lay flat, this is essential so as to fit in a TIC TAC box
1 Locate this point and cut the track.
2 Solder in shorting links
3 Solder in Diode and Resistors
Finaly solder in Transistors and Caps, (Note caps -ve)
STEP 2: Fit in the Box
First Remove sticky lable over the lid
using a craft knife cut a small hole for the wire to exit the box
Place the board inside the box and close the lid around the wires
The final thing to do using insulation tape is to tape around the top of the lid and the box. this effectivly replaces the origanal lable and secures the lid to the box.
8 Comments
Kiran38 6 years ago
Thanks regards
eizen17 11 years ago
Great Circuit. It was Awesome. By the way, can I ask something? Where's the Flasher unit here? Cause I really need to know where's the LED or bulb that would flash here. THANKS!
lrdforster 11 years ago
Please Do Not confuse the bottom connection of the circuit to be Ground or 0v.
Thi two circuits form a simple closed loop 12v from the battery through the flasher circuit, through the switch (still 12v side of the bulb/LED) then back to 0v. I hope this helps
ynovaera 12 years ago
which one is correct?
lrdforster 12 years ago
jimlim 12 years ago
