Simple Paracord Ring
Intro: Simple Paracord Ring
If you are anything like me, you love to make things out of Paracord, but hate to waist anything.
This simple (if over worked) Instructable (my first) should show you how you can use those annoying bits or Paracord that are often left at the end of making just about anything, but are to short to be of any use.
These rings are purely decorative, you wont see them getting Bear Grylls out of a tight spot anytime soon.
STEP 1: Materials
STEP 2: Size and Meassure Your Cord
Rap the Paracord around your desired finger to get the size right.
Measure this against your ruler for future reference.
Make sure that any ends that are sealed or tatty are not counted in your measurements as these will be cut off.
Once you have the right length for your finger add extra 1/8" to 1/4", this will be used in the joining of the ends.
STEP 3: Cutting and Gutting
Go ahead and remove the excess Paracord.
If the other end is sealed or tatty remove it as well.
Pull out and discard the central fibers.
Make sure you do not reseal either end at this stage.
STEP 4: Shaping and Sealing the Ends.
You should now have a hollow tube with two unsealed ends.
Role one end between thumb and forefinger to try and close it down as much as possible.
With your flame lightly melt this end sealing it.
Careful molten Paracord can be painful.
When sealed the end should be as small as possible, it does not need to be completely closed.
With the other end use your tweezers or hemostat to lightly tease the in open and again lightly seal it with your flame.
There should now be one smaller nearly closed end and one widely open end.
STEP 5: Closing the Ring
Tuck the smaller end into the open end.
Use your tweezers to push the it in further.
Check the size on your finger to make sure its not too loose or tight.
STEP 6: Sealing the Bond
When you are happy with the size use the flame and gently heat the mouth of the join this should cause it to shrink slightly gripping the ends together.
You can at this time also clean and flatten any bumps around the rim by melting and flattening with the flat part of your blade.
Do a final size check as you should still be able to adjust it at this time.
Its possible that the bond will now be strong enough.
However if you wish strengthen the bond, heat up your spike/wire until it glows. (do I really need to tell you to be careful with this?)
Insert it into the bond for a very shot time (a second or less), remove the spike/wire and quickly pinch the join, this should melt and bond the two ends together.
This may leave an unsightly mark but twisting the ring will move the mark to the inside of the ring, hiding it when worn.
STEP 7: All Done
Provided you have not made it too tight you shouldn't even feel the join when wearing the ring.
They also have a little stretch to them allowing you to wear more than one on the same finger comfortably, this allows you to match your favorite colours, or show support for your sports teams, school or country.
It may be possible to use this technique to close a more complex Paracord ring, such as a Turks head knot ring, I will look into this and let you know how I get on.
I hope you enjoyed this Instructable and will find it useful.
25 Comments
vknotty 4 years ago
JackG54 8 years ago
Thanks for this!! I'm a total noob to paracord projects. You gave me an idea for making a "breakaway" simple dog collar just to hold her ID tag. Just what I was looking for!
MicheleP13 8 years ago
I am fire challenged. How do I get it hot enough to melt but not hot enough to char the side where the flame catches it?
cool123cool 8 years ago
syiel.cordell 9 years ago
KCBCHSV 10 years ago
thank you for the shirts and stuff
Malkenite 10 years ago
I have been sporting a paracord ring for almost 8 years now. On my second one because I lost too much weight and the first one went down the drain in a shower....
DaggerTA 10 years ago
Smurfy92 11 years ago
Codus 12 years ago
P.S. Nice instructable! :D
clintonmc 12 years ago
Plo Koon 12 years ago
lolmaster2000 12 years ago
The colours are right, but what you did is the Belgium flag ;)
oud25 12 years ago
but i love doing it in black para because it looks like a carbonfiber ring
unclex6 13 years ago
timothymh 13 years ago
Apple_4_life 13 years ago
Lithium Rain 13 years ago
(Nice ible ;)
