Simple Photography Backdrop
Intro: Simple Photography Backdrop
Often when making instructables, the need to photograph small objects arises. This implement helps out, it makes for a softer background than a desk or table. Thus, better photos.
The total cost is under $2, but most of the materials can be found around the house. It's small enough to fit in a desk, so now you can publish all of those "Office Weapons" instructables on location - at the office.
Now, let's get to it.
STEP 1: Tools & Materials
You'll need the following:
- A coat hanger
- Paperclips (not pictured)
- Paper
- Measuring tape
- Pliers, preferably two
- Scissors (optional)
- Electrical tape (optional)
STEP 2: Prepping
Cut the hook off of the coat hanger, so we can start bending. It may take a bit of strength.
STEP 3: Straightening
Straighten out the majority of the hanger, but leave the end bent, we'll cut this off later anyways.
STEP 4: The Initial Bend
Try to find the relative middle of the wire, it doesn't need to be exact. Measure out about 7 inches, or a little less than the width of your paper. Mark it with a pen, or just guesstimate. Then bend both sides.
STEP 5: More Bending
Mark one inch from each bend just made. Then bend these straight up, it should look like the second picture when you're done.
STEP 6: Bending "Eye" Hooks
From the point we just bent, measure 5 inches, or half the length of your paper. At the five inch mark, start bending a "U" shape, and clip the end off, like the second and third photos. Repeat this for both sides. Don't close it all the way yet.
STEP 7: Adding Clips
Slide a paperclip onto the hook, then pinch the hook closed. Make sure the paperclip won't slide off. Repeat on the other side.
STEP 8: Finished!
Just attach a piece of paper with the paperclips, and finished. You can add some electric tape to the corners that touch the surface, for a little grip. Mine already came with a coating, so I didn't do that.
Hoped you liked my instructable, and upload a photo of yours if you make one.
17 Comments
Printy 11 years ago
nsmith1 11 years ago
Kiteman 13 years ago
LOL - now you need an equally-simple lighting rig.
nickodemus 13 years ago
I used an auto-focus camera, obviously it doesn't do it well. And thanks for the idea, a couple of LED's on the top corners would work quite nicely for that purpose...
I need to try it.
When I find that, I focus on an object the distance away, hold the focus and then move back to my real subject.
Kryptonite 13 years ago
To nickodemus; if you can manually change the f stop, try reducing it so you can get a broader field of focus.
Sounds too complicated. I'm just gonna start looking for a better camera.
zascecs 13 years ago
...I never realized that it was so simple! Pretty professional looking... =)
I am going to use this for my next Instructable...
I'm glad I gave the three months of pro to you. :D
