Simple Router Table
Intro: Simple Router Table
If you have a router and and it's a pain in the ass too use it, than this is for you!
In this project we take a router and some basic tools and turn it into a portable router table.
STEP 1: Tools
For this project you need some wood, a router, a drill and a saw or jigsaw.
STEP 2: The Base Plate
We need to take the router and turn it upside down so we can get to the base plate.
Then we unscrew the baseplate and remove it so we can use it as a template. I sawed a new plate out of some plywood and marked the senter so I could mark where i needed to drill some holes. I needed longer bolts becouse the plywood was a little bit thicker than the base plate. Don't use to thick wood because a router can be heavy like mine. You also need to cut a hole in the center for the bits for the router.
STEP 3: Legs
For the legs i took a two by foor and cut it in four equally high legs. This can be difficult if you don't own a mitre saw but with a bit of patients you can get it right. Be sure to make the legs a little higher than the router when it's fully retracted so you won't push up the table when retracting the router. Secure the legs in place and you are done.
7 Comments
TimH22 6 years ago
TonyL200 5 years ago
mw6 8 years ago
thanks for the simple, sweet idea!
kbbaktha 8 years ago
wow such a simple solution and i was going thro dozens of youtubes which were all beyond my means, in terms of power tool resources. Thanks
jcastaneda5 8 years ago
sweet, simple, and it works!... i just put 1 x 6 around the legs for lateral bracing
StevieB1 9 years ago
chipper35 9 years ago
Simple....excellent!!
