Introduction: Simple Stand for Camera
For a good video and photo, you need a stable and reliable stand. In this lesson I want to show how to make a simple and affordable stand for filming
Step 1: Materials:
- Sheet chipboard
- Metal corners
- Screws
- Camera mounts
- And tools
Step 2: Production of Parts
To begin with, I cut out two sheets of an isosceles triangle (equal sides of which are 13.5 cm) and cut out a small triangle on one of the vertices (side dimensions of 1.5 cm). After that, I cut out a rectangle(12x16 cm)
Step 3: Production of Parts
Then I cut a corner into two parts and drilled holes in them, as in the photo. Also need to make a hole in the previously cut rectangle
Step 4: Installation
We collect everything as shown in the photo
Step 5: Mounting Under the Camera
On the bolt fixing the camera you need to wear a few washers. Then insert into the hole and from the other side put the pad on the camera
Step 6: Shelf Mounting
We need to twist our design to the shelf
Step 7: End
It's all. Have a good video and photo
