Simple Toothpaste Dispenser
Intro: Simple Toothpaste Dispenser
Have you ever thought about how it's discusting to share toothpaste with your family? There are so many germs involved in that process! Or Have you ever been frustrated while trying to squeeze out the last bit of toothpaste? If yes then build on Well in this instructable i'm gonna show you a solution on how to avoid these obstacles.
What you do is you put your toothbrush under this dispenser then push the button to get toothpaste.
VOTE FOR ME IN THE HEALTH CONTEST PLEASE!!!! thank you sooo much
STEP 1: Gather Tools and Materials
Materials needed:
-hard plastic cup
-spring from pen
-top of soap dispenser
-pieces of plastic
-Silver spray paint
-3-4 inch long nail
Tools needed:
-scissors
-hot glue gun
-hard plastic cup
-spring from pen
-pieces of plastic
-Silver spray paint
-3-4 inch long nail
Tools needed:
-scissors
-hot glue gun
STEP 2: Hot Glue Plastic to Inside of Cup
With scissors cut two pieces of hard plastic and glue on opposite sides to inside of cup. Make sure that it is big enough for a toothpaste tube could fit in it. Now time to get ready for the next step!
STEP 3: Make the Spring Mechanism
This part may be a little confusing but thats why I have pictures. First put a hole in the bottom of the cup centered. Next put a hole in the side centered anywhere you want the dispenser. Now with a nail around 3-4 inches long glue the sharp end to the soap dispenser end. Next slip spring over nail and make it so it stops where the nail and dispenser meet. Glue the end of the spring to the dispenser. Now with hard plastic cut out a washer shaped shape and slip it on the other side of the spring. Now put it all in the hole and Glue washer shape to outside of cup. Now test it out.
STEP 4: Spray Paint It Silver
Spray paint this now so it is all silver.
STEP 5: Mount It and Add Toothpaste
You can now put a tube of toothpaste in and make adjustments if needed. Good luck with this new instructable! You may even mount it by your toothbrush!
4 Comments
Kanein Encanto 13 years ago
So the way this is working is you press the soap dispenser top and it pushes on a small spot on the tube every time? I have to say if that's the case, this'll work for a couple presses and then stop as the tube doesn't spring back, nor does most toothpaste flow.
Or am I'm missing something in the construction yet?
zoe- 13 years ago
dombeef 13 years ago
Houdinipeter 13 years ago
