Introduction: Simple and Fast Heart Wheel Bracelet
This is an instructable on how to make a Lovely Hearts Bracelet using a bracelet wheel. This bracelet is different from regular bracelets because you get to use a bracelet wheel! Enjoy!
Step 1: What You'll Need
String ( Embroidery floss works best )
  - You will need two colors of string. You will need 3 40 inch strands of  whichever color you choose for the hearts.
   - You will need 5 40 inch strands of the color you choose to be the outside.
Scissors
Cardboard or Foam
A ruler
Step 2: Making the Wheal
Cut a circle out of the foam( or cardboard ) with a diameter of about 5 inches. Then cut 33 little cut-outs from the perimeter of the circle about a half inch apart. Then cut a small hole in the center of the wheel with a diameter of about an inch.
Step 3: Setting It Up
Choose a color you would like for the hearts and cut 3 strands each with a length of 50 in.. Then choose a color for the outside and cut 5 strands 50 in. long. Gather all the strings and in the center tie a loop.
Set up the strings as shown on my wheal by pushing the strings into the little slots around the wheel.
On the top of the wheel write start.
Step 4: Making the Bracelet
Take the right string from the top and move it down to the right of the bottom set of two strings. You should then take the left string ( from the bottom set ) and move it to the top ( the set of 1 ) on the left side. Next turn the wheel to work on the next set. If this is confusing don't worry its easier to understand in the video. Next just keep going around and around until your bracelet is long enough to fit around your wrist.
Step 5: Finishing
Put the rest of the string through the loop and tie a knot and cut extra string.
