Simple Garden Chair From Old Bicycle
Intro: Simple Garden Chair From Old Bicycle
Used parts off a old bicycle to create this chair, a length of 70mm treated wood and a few bolts/screws.
STEP 1: Bike
I used the pink & purple bike at the font of the image.
STEP 2: Rims and Legs
Removed the rims, simply loosened the nuts and the wheel was removed. Removed the threaded bar through the center of the rim, remove nuts.
Release air from tube, tube was removed by hand but a screwdriver for leverage would help.
Cut legs to desired length.
STEP 3: Chair
M6 40mm bolts with nyloc nuts were used, ideally longer bolts would of been used as I had no room for washers.
Drill a 6mm hole on each rim, drill hole in leg so top is flush with rim, bottom hole far up enough bottom of rim is of the ground.
Same again for other legs
STEP 4: Back and Finishing
Two longer strips were used for the back of the chair, the gap seems large but sitting back feels fine.
Mud guards were used on the sides.
Front and rear reflectors were screwed to the tops of the back.
3 Comments
ashleyjlong 8 years ago
I had the same thought. Really cool industrial piece but I'd find some cute bike themed fabric to make a cushion for that top! Or a glass top to make it a table and show off the wheel spokes. Very neat either way!
mtairymd 8 years ago
Interesting design. I like how you've incorporated multiple parts from the bike. I've never considered sitting on a bike rim. It seems like it might hurt after a few minutes.
Lordii 8 years ago
Surprisingly it isn't to bad although I haven't yet sat on it for a long period of time
