Simple T-shirt to Skirt
Intro: Simple T-shirt to Skirt
Make an easy skirt from a t-shirt. I bought mine for $3 at the craft store. The possibilities are endless since you could use any t-shirt--including old vintage Ts. I decided on neon yellow for a cheap way to embrace a trend. The finished product will have a little ruffle down the front. T-shirt jersey is a great and easy fabric. It does not fray, so you don't have to finish all edges unless you want to. I prefer unfinished....gives it a bit of edge!
STEP 1:
I chose an XL size T. I am a size 8 and I had enough fabric to fit. If you need more fabric, you could use two t-shirts and sew them together.
STEP 2:
Cut off the arms. I then used my rotary cutter to get a straight line across just above the armpit area.
STEP 3:
Just to make sure I was on the right track, I slipped the jersey tube on to see how much extra fabric I had.
STEP 4:
Based on my try-on, I cut several inches off to my desired length. I also cut straight down the tube, basically making one big rectangle.
STEP 5:
After cutting, I went back to the mirror to pin the skirt. I chose to use the hemmed part of the shirt at my waist. I started at the waist, pinning to desired tightness. I then pinned down the cut in an A-line shape, making the ruffle smaller as I approached the bottom hem.
STEP 6:
CAREFULLY remove your skirt so you don't get poked by pins. Check to make sure the pins are in a straight line. Note that the pins give a bit of an A-line.
STEP 7:
Sew a seam alongside your pins. Be sure to backstitch at the beginning and end to ensure your seam doesn't come out.
STEP 8:
Done and done. Enjoy your new skirt! I plan to make a few of these next summer. I'm considering adapting this a bit to make a long one in a nice jewel tone jersey for fall.
5 Comments
occasion.prints 9 years ago
Very helpful and creative tutorial! if you need blanks just let me know, thanks!
CraftWars 10 years ago
grayjay 11 years ago
Muhaiminah Faiz 11 years ago
jessyratfink 11 years ago
