Simulation Study of a Bar Having Circular Cross Section Under Compressive Force
Intro: Simulation Study of a Bar Having Circular Cross Section Under Compressive Force
In this project i have used fusion 360 of auto desk.
I have made a bar having circular cross section.
Then I have applied a compressive force on it.
I have used model and simulation work space of fusion 360.
I have analysed the body for stress produced, strain produced, reaction force produced,
safety factor, and displacement.
I have used steel as a material for bar.
STEP 1: Sketching
In this step I am in the model work space of fusion 360.
Then I have drawn a circle on the top plane.
STEP 2: Extrusion
Then I have extruded the circle drawn in previous step.
STEP 3: Stress Analysis
In this step I am in the simulation work space of fusion 360.
Then I have fixed one end of the steel bar.
Then I have applied a compressive force of 500 N on the opposite face of
steel bar.
Then I have analysed the bar for stress produced.
The red color shows maximum value of stress.
The blue color shows minimum value of stress.
We can observe that the minimum value of stress is on the fixed side of the bar, but
around the longitudinal axis of bar.
The maximum value of stress is .06445 M Pa.
The minimum value of stress is .03021 M Pa.
STEP 4: Displacement Analysis
Then I have analysed the bar for the displacement produced.
The red color shows maximum displacement.
The blue color shows minimum displacement.
The maximum value of displacement is 8.753 E -05.
The minimum value of displacement is 0 mm.
We can see that minimum value of displacement is around fixed end.
We can also observe that maximum value of displacement is around free end.
STEP 5: Reaction Force Analysis
Then I have analysed the steel bar for the reaction force produced.
The red color shows the maximum value of reaction force .
The blue color shows the minimum value of reaction force.
We can observe that maximum reaction force is around the fixed end.
The value of maximum reaction force is 14.87 N .
The value of minimum reaction force is 0 N.
STEP 6: Strain Analysis
Then I have analysed the bar for the strain produced.
The red color shows maximum value of strain.
The blue color shows minimum value of strain.
The value of maximum strain is 4.123 E -07.
The value of minimum strain is 1.537 E -07.
Strain has no units because it is the ratio of two similar quantities.
STEP 7: Safety Factor
In this step i am in the simulation work space of fusion 360.
In this step I have provided the safety factor involved in this case.
The maximum value of safety factor is 15.
The minimum value of safety factor is 15.
Factor of safety is the ratio of maximum load and safe load.
7 Comments
JamesT396 6 years ago
And finally, do you trust the safety factor you found? Why is it uniform if your stress field isn't?
I'm not trying to be too hard on you, but I'll finish with the question I always asked when I was teaching a FE course. Do your answers make sense? Assuming that this is supposed to be a purely compressive bar problem, this is a pretty simple problem with basic mechanics. Do a couple quick calculations to make sure your result is in the ballpark.
Finite element analysis is hard and it takes time to get it correct. Keep working and you'll get better!
medanilevin 6 years ago
Nice first try.
You have really to refine the mesh.
And for simple case like this there are closed form solution. Circular bar in compression has uniform stress distribution, certainly on the outside where you look.
And if you compress bar with 500N, your reaction force is 500N. There is no way around it...
FYI, There is little value of obtaining solutions per node. It has no physical meaning.
And, I really want it to sound positive and constructive, it is the first advice I give my engineers: If you obtain results from FE code, they are not automatically right.
Dani
dchesson93 6 years ago
ankitthakur1998 6 years ago
