SineWave Generator for Arduino DUE
Intro: SineWave Generator for Arduino DUE
A sketch to generate a sine Wave using Arduino Due
The wave is generated by outputting pre-calculated voltage levels through the DAC on the arduino DUE board
Required:
1x Arduino DUE
2x Jumper wire
Setup:
Using a jumper wire, connect DAC0 on the Arduino to the desired target that should receive the wave
If ground connection is required:
Using a jumper wire, connect GND on the Arduino to the ground connection on the desired target.
The sketch offers 5 different waveforms with different frequency and levels of granularity. Follow the documentation in the sketch to uncomment the desired wave.
Resulting waves:
7 Comments
СергейИ22 2 years ago
serious programming experience with the Arduino Due. I would like to create a
signal generator with visualization of the results on the monitor screen of EVIVE
(StemPedia). Unfortunately, it is difficult to understand the code, since there
is no electrical diagram of the project. For example, what is the role of
buttons in a project. Could you send me the wiring diagram of the project.
pinMode(buttonPin1, OUTPUT);
pinMode(interruptPin1,
INPUT_PULLUP);
gavrilo.jelic 3 years ago
Thank you for the thorough code with comments!
Two things I am confused about are the two Ints,
F = xxx; // for frequency
and
waitTime = 1000/F;
I don't see them being used anywhere other than being declared, why is that?
Bhavaprasad 4 years ago
Vlad6511 7 years ago
Arduino UNO
tanyagizell 7 years ago
Im afraid the arduino UNO has no DAC and cannot support this implementation.
I have only tested this on a DUE, but technically the zero and mkr1000 could also work.
good afternoon. Tell me on arduino it works? The error in line 107 ('analogWriteResolution' was not declared in this scope). Tell me what to do. Thank you.
DIY Hacks and How Tos 7 years ago
Interesting. I have never seen a wave generator like this on an Arduino before.
